Propeller Sleeves
1029 9 2020-3-15
Durlano
Flight distance : 90453 ft
North Macedonia
Hello Pilots!
I just wanted to share my simple_basic_5minutes design for "sleeves" for the propellers on Mavic mini...
Intro:
From the moment of having the Mavic Mini Combo I didn't liked the way how propellers are moving everywhere when removing and especially when putting back the drone in the case.
In order to solve this I have ordered two designs of propeller holders, hard plastic ones, as well as rubbery ones. Well, it didn't work for me. The rubbery ones are two tight and I didn't want to put any stress to the fragile leg design. The hard plastic came with one loosed that fits without any strain - it is just as cap and I use it for the top propellers. The other one for the down facing propellers is two tight and also didn't fit completely in the case. For that I have created very simple paper sleeves for the propellers.
Design:
I just used simple thin paper (in my case gift wrap paper ) folded in the middle and ends connected and glued with simple paper glue tape.
The dimension is: 4 cm width (when folded in the middle gives 2 cm - roughly the width of folded propellers) and 5 cm long.
Cut the paper with the width of 4cm length of 11-12 cm, fold in the middle, connect the ends with paper glue tape, then cut the ends to get even cut, cut two pieces of 5cm each, and trim edges as in pictures...
Hope it helps...
Take care....
Papper_cut_fold
Papper_cut_fold
Final_cut
Final_cut
Install
Install
Install
Install
2020-3-15
Ralle
Flight distance : 11289 ft
Finland
2020-3-15
Hello and good day Durlano. Thank you for reaching out and for sharing this very innovative accessory you have created for the DJI Mavic Mini. Great work and fly safe always. .
2020-3-15
m80116
Flight distance : 3264131 ft
I admire your genius... personally I am quite practical. Once I cross the folded props I tie them together with velcro like (flattened) cable ties. Works great for me.
2020-3-15
Traxx119
Nice and simple case friendly prop sleeves. Good idea and thanks for sharing!
2020-3-15
Lucas775
Flight distance : 50642090 ft
Excellent idea!
2020-3-15
Cal Evans
Flight distance : 85673 ft
Very cool!
2020-3-15
120ccpm
Flight distance : 1401115 ft
I had the exact same reaction when I saw how thin the MM props are, and purchased both hard-plastic and rubber "prop savers" off eBay. Didn't like either type, so at the end I modded my MM case (another eBay purchase, not the official DJI case included in the Fly More Combo) so that the AC would basically rest on its body, putting no weight on the (bottom) props.  For the top props, I did cut out some foam  so that  the case lid would not push down on them directly.
2020-3-15
Very creative.
2020-3-16
Woe
Flight distance : 4129268 ft
Cool
2020-3-16
