PHANTOM 3 ADVANCED - after firmware upgrade no connection?
5197 32 2020-4-13
mattskiii
Flight distance : 2290 ft
I have a relatively new P3A that I haven't flown in several months. This morning I started it up with no problems, but noted that on the DJI GO app screen it stated that my firmware for both the remote and drone needed to be updated (makes sense as I haven't flown in a while). I did the RC update 1.9.2 through the DJI GO app (simple enough), and then downloaded the drone firmware update 1.11.20 and installed on drone (with no problems). When I re-started the RC and drone after these 2 firmware updates, I get the following: Camera does not work (can't see on DJI GO app); rear blinking yellow lights with constant red lights on front of drone; DJI GO app says in red at top of screen, "Remote Controller Signal Weak". Appreciate any help whatsoever as I'm definitely a newbie at this. Thanks so much! -matt c.
2020-4-13
Eduardo Silva
Flight distance : 28757 ft
Also mine does not even reach 700 Distance already gives weak signal every time. Help ?
2020-4-13
DJI Natalia
Hi mattskiii, please restart the aircraft and the remote controller to see if the issue still persists or not? If yes, please record a video to show us the details of the issue, we'd like to help you check it. Thanks.
2020-4-14
DJI Natalia
Eduardo Silva Posted at 4-13 21:26
Hi Eduardo, Which drone do you use? Could you please check if there is an error message prompt in your APP? If yes, please show us a screenshot of the error page, we'd like to help you check it.
2020-4-14
Eduardo Silva
DJI Natalia Posted at 4-14 04:50
he doesn't even give an error message he does it alone without show or error just says ke lost the Drone signal so mine is DJI Phantom 3 Advanced version 1.9.2 drone 1.11.20
2020-4-14
mattskiii
DJI Natalia Posted at 4-14 04:47
Hey Natalia, yes, even after restarting the RC and aircraft several times, I continue to get the same problems: Camera does not work (can't see on DJI GO app); aircraft rear blinking yellow lights with constant red lights on front of drone; DJI GO app says in red at top of screen, "Remote Controller Signal Weak". I will record a video of these issues and post shortly. Thank you so much for your help on this! Cheers! 
2020-4-14
Eduardo Silva
2020-4-15
DJI Natalia
mattskiii Posted at 4-14 07:52
Hi mattskiii, I have sent you a PM, kindly please check and download the firmware to see if it helps or not. Thanks.
2020-4-15
DJI Natalia
Eduardo Silva Posted at 4-15 16:37
Hi Eduardo, I have sent you a PM, kindly please check if it works or not. Thanks.
2020-4-16
mattskiii
DJI Natalia Posted at 4-15 23:58
Natalia, I did not receive your PM. Could you resend? Also, I couldn't figure out how to send a video (file too large). But I did take some pictures throughout the startup process. Can I send?
2020-4-21
mattskiii
2020-4-21
PaoVill24
Flight distance : 193271 ft
Philippines
Hello. Try downloading the firmware from the DJI site. I had same issue when I upgraded the firmware. It was resolved when I used the SW from the DJI site.
2020-4-21
JetSam
Flight distance : 3462946 ft
I would try reinstall The Dji app
2020-4-21
mattskiii
PaoVill24 Posted at 4-21 17:25
Sorry, but what does "SW" mean?
2020-4-22
DJI Natalia
Hi mattskiii, thank you so much for providing the pictures. You are recommended to re-upgrade the firmware and then try the connection again, please make sure the firmware update success and the remote controller firmware should be compatible with the aircraft firmware.
2020-4-22
mattskiii
2020-4-23
mattskiii
JetSam Posted at 4-21 23:31
I did reinstall - same results.
2020-4-23
mattskiii
DJI Natalia Posted at 4-22 22:26
When I try to re-upgrade the firmware, it is unsuccessful, stating that latest firmware is already on drone. Is there a way to rollback the firmware, and then try to re-upgrade? Thank you.
2020-4-23
JetSam
mattskiii Posted at 4-23 08:06
yes, via Dji Assistant you can roll back to the previous firmware
2020-4-23
JetSam
2020-4-23
mattskiii
JetSam Posted at 4-23 08:16
I've downloaded DJI Assistant, but it won't connect to my drone. Crazy.....
2020-4-23
mattskiii
JetSam Posted at 4-23 08:17
https://www.youtube.com/watch?v=ysW8sW0Xnos
Thank you for the video. Question I have is where do i find an older version of firmware to roll back to? Right now I have latest firmware version 1.11.20 on my P3A. Thank you for any help on this.
2020-4-23
mattskiii
mattskiii Posted at 4-23 08:46
2020-4-23
mattskiii
I power-up drone, connect to computer, open DJI Asst, and this screen appears but doesn't connect...
2020-4-23
mattskiii
The firmware I originally downloaded was from the DJI site. I've since re-downloaded and reinstalled with the same results....
2020-4-23
JetSam
Make sure DJI Assistant is allowed in the windows firewall
2020-4-23
mattskiii
JetSam Posted at 4-23 22:44
2020-4-24
mattskiii
I did. Still will not connect...
2020-4-24
JetSam
then you must wait for a moderator help , sorry
2020-4-25
mattskiii
JetSam Posted at 4-25 00:13
then youmust wait for a moderator help , sorry
Copy that. Who is the moderator?
2020-4-26
JetSam
mattskiii Posted at 4-26 09:09
DJI Natalia
2020-4-26
DJI Natalia
Hi mattskiii, sorry for the inconvenience. I have replied to your PM, if the issue still persists, you are recommended to contact our support team via http://www.dji.com/support to open a case and send the drone in for service. Thanks.
2020-4-26
mattskiii
I could only find DJI Assistant 2 (which is for Phantom 4 not Phantom 3). Is there a DJI Assistant that is compatible with my P3A? Tx!
2020-4-27
