A J
![](https://forum44.djicdn.com/data/attachment/common/4e/common_26_usergroup_icon.png) Captain
Flight distance : 14754314 ft
M4cr0s Posted at 7-6 02:52
In course lock and waypoint modes I believe one can select 2s intervals as well, even at 8k, just not in free and circle. Some samples I've seem to indicate capture interval makes no difference. It is a bit confusing. but must be about processing power.
Also, the processing delay when shooting "normal" 48mp photos indicates that the device is doing some pretty heavy stuff. Not surprising, since this isn't "real" 48mp as in 48mps worth of color and light capturing RBG pixels. Bottom line, it is and always will be a 12mp sensor and digital cleverness can't change physical facts. Maybe this pulls processing power away from balancing and positioning it in the air, causing more jerkiness. I dunno.
I'll have to check that later - got four fully charged batteries - just waiting to see if these 30mph winds settle...
Yep, the MA2 has a 1/2' 12mp Quad Bayer sensor. The '48mp' stills do look very impressive from such a small drone but it is not true native 48mp. The placement of 2G, 1B, 1R behind each pixel rather than just one colour in each pixel with a normal bayer sensor does pull on more processing power from the drone to create a still image that replicates the look of 48mp. The same is true with the video as, for example, APAS and FocusTrack is disabled when recording in frame rates higher than 30p like 4K60p due to the processing power needed. |
