Verify ADSB / Airsense
729 5 2020-7-23
K3v1n
Flight distance : 158698 ft
I owned a MA2, US spec with ADSB (came with the sticker).  I just recently had it replaced under DJI Care, the replacement drone did not have such sticker. I can't seem to find anything in the app which mentions airsense / ADSB.  I thought there was something previously in the safety menu.
Any idea on how to verify if ADSB/Airsense is on this drone?
2020-7-23
Rustic17
Flight distance : 2733760 ft
Wait until a helicopter or low flying plane passes overhead...that said, I know of no other way to verify you have it.  Your replacement drone was probably a refurb without all the stickers.
2020-7-23
MisterFrag
Flight distance : 603143 ft
The map display will have an aircraft symbol at the right edge of the window where you can adjust the sensitivity of the AirSense warning system. If it’s not there then ADS-B is unavailable; if it is there you can bump up the sensitivity to the maximum setting and increase the potential of receiving a warning. At the maximum setting, I get warnings for commercial aircraft flying thousands of feet directly above.
2020-7-23
Rustic17
MisterFrag Posted at 7-23 21:32
Thanks for the info!!!
2020-7-23
K3v1n
When you say unavailable is there a reason outside of the drone is not adsb equipped for it not to show?
2020-7-24
Hi K3v1n, the replacement drone is ADS-B version upon checking the SN in our system, no worries.
2020-7-24
