Flying above 3000 m
7513 34 2020-5-30
mbehzadpix
Flight distance : 2177421 ft
Hey Guys!
in MM User's manual, it s mentioned the max height that the Mavic Mini can fly is 3000m!
My question is  that whether it s kind of advice or we are limited to fly under this partcular height!
2020-5-30
Mizzu
Flight distance : 431873 ft
To be honest, I wouldn't even try to fly that high.
First of all: Everything looks like viewing something in Google Maps. Everything just looks boring and the same.
Second: The Mini is too light and very sensitive to wind. I would be pretty afraid about that it gets blown away or something like this. I'm pretty sure you can expect heavy trouble in these heights with something small like the Mini. If you're willing to risk 400€, feel free to give it a try. ;)
2020-5-30
sbonev
Flight distance : 3665279 ft
there are a lot of videos from heights above 3000m you can check on youtube, i think i have seen as up to as 3600 m height
2020-5-30
JJB*
Flight distance : 12686732 ft
Mizzu Posted at 5-30 03:29
I think he means to start flying at 3000 meter, i.e.  from a moutain etc
2020-5-30
AndreaBB
Flight distance : 542044 ft
MM is limited via software to 400 meters in height from the take off point. That value is in case you want to take off from a mountain
2020-5-30
AndreaBB
2020-5-30
mbehzadpix
JJB* Posted at 5-30 03:54
Exactly! starting from somewhere above 3000 m in mountains
2020-5-30
JJB*
mbehzadpix Posted at 5-30 04:36
guess the limited power of the MM will cause problems flyinh that high.
Not only height but temperature and barometric pressure will have effect.
So start a flight and be very carefull, keep in mind that max power warnings are possible.
cheers
JJB
2020-5-30
Hi, thanks for reaching out. Yes, you can fly on that specific height as indicated on the website as a maximum takeoff altitude of the DJI Mavic Mini. However, we strongly suggest to please make sure that the drone is well calibrated and also please make sure that you are flying on a recommended temperature to avoid any possible errors. Please be more careful about flying on this height. Please let us know if you have other inquiries or concerns. Thank you for your support!
2020-5-30
PhasedSpaces
Flight distance : 185463 ft
Here's a video of a mini flying at 3500m above sea level...  No sweat..
2020-5-30
djiuser_RIeSM3mAo5mf
Flight distance : 542083 ft
Very nice vídeo
2020-5-30
mbehzadpix
PhasedSpaces Posted at 5-30 10:01
Here's a video of a mini flying at 3500m above sea level...  No sweat..Video
Very Nice! Thank you
2020-5-30
Renato61
Flight distance : 168163 ft
AndreaBB Posted at 5-30 04:12
MM is limited to 500 meters, but the question is flying in mountain.
2020-5-30
Guorium
Flight distance : 513061 ft
3500m no probs here. So be gentle on the sticks. Braking time is a bit longer than at sea level
2020-5-31
sbonev
stephjant Posted at 6-1 02:43
Why are people even discussing this. In the U.K. you cannot fly above 120 metres. The idiots that flaunt this rule are just going to spoil it for the rest of us as more regulations are brought in because of the idiots
why are you even commenting if you don't have anything higher than 1500 m there and the question is not how high you can fly the drone but the height at taking off...
2020-6-1
Flight distance : 10186312 ft
You can fly the mini as high as the radio signal will allow, so I presume 4 miles USA. Only problem you’ll have is bypassing djis limit of 500m altitude.
2020-6-1
virtual
Flight distance : 4897142 ft
Czechia
Nice video!
2020-6-1
Francoisd
Flight distance : 66352 ft
Very nice video. We have so beautiful landscapes in France
2020-6-1
NightThunder
Flight distance : 106020 ft
The 3000M is a MM limit is merely the service ceiling which is measured above mean sea level (MSL) and the max height MM can safely be flown. It is NOT the height above the ground (AGL). The two are NOT related. The service ceiling is not an absolute limit as is not a limiting factor on how high it can be flown and you are not limited to 3000M as long as your drone is within 400' AGL. This means you can fly your drone legally above 3000M as long as the MM is within 400' AGL.
2020-6-1
Daniella3d
If people start sending their Mini at that altitude, the government will control it and you and every body doing those dangerous behaviors will totaly ruine the hobby for the rest of us.
I guess taking off from a mountain is different, but the wind can be 10km at ground level and be 100km at 3000 feet. bye bye drone.
YOu can check www.ventusky.com before flying. you can check at many altitude and on different dates. Very useful!
2020-6-5
Athiril
The air gets thinner and the load on the prop goes down which means less thrust and less current draw from the motors, there’s videos online showing the Mini dropping because it doesn’t have enough thrust in some areas on a mountain, it could happen on a very hot day too
If you have some kind of prop adapters where you can put either bigger props on, or props with more pitch etc (or even, 3, 4 blade props) you can get the current draw back up and produce enough thrust to fly in thinner air
2020-6-5
Athiril
Everybody else in the world should follow UK laws rather than their own country’s and also only fly from sea level
2020-6-5
Gregory.Opera
Flight distance : 151122 ft
This was my understanding - that this figure refers to the maximum altitude you can take-off from, not the maximum altitude you can fly to.
When I first got my Mavic Mini, I was playing around with my settings and discovered that I could fly my Mavic Mini as high as 500M (relax - I was in a remote area with no air traffic)... It's interesting to know that my drone can fly that high, but I don't think I'd make a regular habit of it because the wind is awfully strong at that height, it's unnecessasary (how often does one actually need to operate at this height in the Real World?) and of course, it's awfully dangerous to fly at such a height (jets, helicopterrs, etc).
I'm sceptical that the Mavic Mini could hit 1,000M, let alone 3,000M - and to be honest, I don't think that consumer drones should even have that capability...
2020-6-6
BrokenKds
Flight distance : 344423 ft
Learn to read moron.
2020-9-26
nevac
Flight distance : 9828796 ft
Serbia
I did not fly over 3000 m because we do not have such a high mountain. I flew at altitudes from 1200 to 2400 m without any problem.
2020-9-26
K6CCC
Flight distance : 651683 ft
All aircraft have a service ceiling.  In the case of real aircraft (either fixed or rotary wing), here in the US, there are rules in the part of the FAA rules that relate to aircraft certifications, that define what constitutes the service ceiling.  As I recall, it is something like the density altitude where rate of climb drops down to 50 feet per minute at max rated weight.  Several factors effect the rate of climb of an aircraft.  One of the biggest is loss of power from the engine because of less oxygen available to the combustion chamber due to less ambient air pressure.  This can be partially compensated for by turbocharging the engine.  However some of the other factors are not that easy.  Propeller efficiency drops off with less ambient air pressure.  That can be compensated for by designing a propeller for high altitude flight.  A variable pitch propeller helps, but not completely.  Wings can be designed for use at higher altitude as well.  There are a few other factors as well, but that is the obvious major ones that the aircraft affects.  Temperature, humidity, and atmospheric pressure also have a factor - and we humans have no control over those.  For a fixed wing aircraft that is not turbocharged, performance falls off the higher you get.  Helicopters are the similar.
Of course for our electric motor powered drones, loss of engine performance due to less oxygen being available is not an issue!  However wing / propeller efficiencies and the weather related factors still do.  There will be a density altitude where a Mavic Mini will be incapable of lifting itself off the ground at all.  That is likely well above the previously mentioned 3,000 meters.  However at 3,000 meters, I would expect performance to be much poorer than it is at or near sea level.  In a  couple weeks, I will be at Mammoth Mtn in California with my drone.  That is around 3,000 meters and I will be doing some flying.  I have every expectation that performance will be substantially degraded - I know mine is!
In full disclosure.  I am a licensed fixed wing pilot with a Commercial license with Airplane Single Engine Land and Instrument Airplane ratings.  I learned some of the rules behind how service ceilings are determined in ground school - but that was almost 45 years ago.  I need to know what the service ceiling of an airplane that I fly is, but not how the rules determine what that service ceiling is (Cessna can worry about that part).
2020-9-26
Gregory.Opera
And here come the Drone Police...
*Rolls eyes*
No  it's not - I've hit 500 meters with my Mavic Mini... It's hard to do  though, because usually the wind just become too much for the Mavic  Mini; it needs to be an especially calm day.
2020-9-26
Gregory.Opera
2020-9-26
Gregory.Opera
Daniella3d Posted at 6-5 17:01
UAV Forecast is handy, too... Like Ventusky, they have both a website and applications for Apple iOS / Google Android.
I  have preset the hardware limitations of my Mavic Mini (e.g. it's maximum wind  tollerance, it's maximum environmental temperature, etc...), then all I  need to do is open the application and I can see at a glance whether I'm  good to go or not.
I also use the Ventusky application, but mostly for the wind direction (because I live in a coastal city, next to the Pacific Ocean)... UAV Forecast is my primary go-to application.
2020-9-26
AntDX316
Flight distance : 3394731 ft
nevac Posted at 9-26 09:08
https://youtu.be/aDmPj86ld5I
Was that w/ the Mavic Mini?
2020-9-26
nevac
Serbia
AntDX316 Posted at 9-26 20:45
Yes everything was filmed with a Mavic Mini
2020-9-27
Droneflier
Flight distance : 1811322 ft
Great videos guys Thank you
2020-9-27
AntDX316
nevac Posted at 9-27 00:19
Was it straight off the camera or edited?
2020-9-27
nevac
Serbia
AntDX316 Posted at 9-27 07:06
Everything has been edited in Adobe Premiere with color correction
2020-9-27
