Mavic Mini 2 Type (FCC, CE)
15131 12 2020-11-4
JackChoi
Flight distance : 16284928 ft
South Korea
Mavic Mini is known to come in two types, CE and FCC aircraft. How about the Mavic Mini 2? Will the Mavic Mini 2 also come in two types? Can I buy the FCC type Mavic Mini 2 in Korea? The FCC type Mavic Mini aircraft could not be bought in Korea.
2020-11-4
WernerD
Flight distance : 350837 ft
Austria
Same question. I will by a Mini 2 only if a C0 EU drone law sticker will be made available. But I have not found any information about if DJI will take care of it, if the first batch will not include a sticker but later, if the Mini 2 will never get such certification ever.
Any official statement?
2020-11-4
Hello there JackChoi. Thank you for reaching out and for the inquiry. The DJI Mini 2 supports 2.4 GHz and 5.8 GHz simultaneously. In areas that support both frequency bands, the DJI Mini 2 switches to the optimal frequency band and channel according to the signal conditions. For additional reference, I will post a link where in you can find the specification, overview and frequently asked questions for the DJI Mini 2 ( https://www.dji.com/mini-2?site=brandsite&from=nav ). Again, thank you for your valued support and make your moments fly. .
2020-11-4
It will still pick the radio system that's legal for the country you are in.
2020-11-5
nixuspix
Flight distance : 2864974 ft
Latvia
It's very unfair to advertise FCC Transmission Power  of the new Mini 2 in section for EU buyers. No one word about transmission Power distances in CE regions. I mean how far signal is transmitted in Urban, suburban and obstacle free areas. For FCC you clearly state 3km, 6km and 10km
Are hiding something from us DJI?
2020-11-5
CemAygun
Flight distance : 810 ft
Philippines
Good to know The first mini had region specific versions...
2020-11-5
itsdavesdrone
Flight distance : 6763835 ft
nixuspix Posted at 11-5 01:20
CE and SRRC regions are advertised as 6km and it's 10km in FCC regions.
2020-11-5
Alevpi
Flight distance : 43560 ft
itsdavesdrone Posted at 11-5 14:08
But in reality, we see that less than 6 kilometers is due to the capacity of a standard battery.
And the deterioration of weather conditions, video recording and non-linear flight and the degradation of the same battery will only further reduce the flight range.
2020-11-6
djiuser_s5zpg6g0B1Vf
United Arab Emirates
DJI Stephen Posted at 11-4 21:55
Hi DJI support,
Please could you specify more?
Previously with Mavic Mini 1, FCC models were limited to 500 meters in CE countries.
Previously the specs were very clear based on the two models FCC or CE.
Please could you share similar info. Im buying a FCC model I want to know if i will have distances issues in CE countries such as France or UK.
Please could you be specific DJI support?
2020-11-11
djiuser_ePgruPdNNSyO
Flight distance : 348547 ft
Unlike the MM, there is no "FCC model" as you suggest for the Mini 2. It's just one 'international' model for everyone (OK Japan has its own version).
As someone has previously said. It will adjust the settings based in the country you are flying in. So you will have the increased range when you fly in the US, and the reduced range when you fly in Europe.
2020-11-11
djiuser_ePgruPdNNSyO Posted at 11-11 15:58
All right, getting it now.
Thanks.
So only 1 version for everyone
2020-11-11
videoeditman
Flight distance : 6713271 ft
The Japanese version needs to be under 200 grams, But I believe it's only difference is a smaller lighter battery, therefore reduced flight times.
2020-11-13
djiuser_kZi2jW1n6rGo
Flight distance : 1001631 ft
Brunei
Hi. May I know if my DJI Mini 2 is CE or FCC mode? Thanks in advance.
2021-6-25
