Drone for Shark Fishing
1156 5 2021-2-6
asampau
Argentina
Hello guys:
  I'm from Argentina, I used to go to beach. I like to fish sharks. So please tell me something regarding
Please tell me if the phatom 4 drone has been tested to transport shark fishing lines.
Consider that the fishing line with the plumb bob and bait has a total weight of 1kg, the fishing line can be a 0.45mm multi-filament so as to have less wind resistance that can be up to 30km / h.
Thanks in advance.
2021-2-6
Cetacean
Flight distance : 2528264 ft
Aloha asampau,
     No, fishing is not an approved use of the P4.  DJI does not support such uses.  However, I do not work for DJI and do not speak for DJI.
     Take care and be safe!
Aloha and Drone On!
2021-2-7
Hi, asampau. Thanks for reaching out! We appreciate your inquiry, however, the Phantom 4 Series are not specifically designed for fishing and we have not attempted to test this, so far. Your kind understanding is highly appreciated.
2021-2-7
Im not sure about Argentina,  but many countries have rules against drones dropping things,  you might want to check up on the local rules.
2021-2-7
asampau
Argentina
Hi Guys, thank for your quickly responses.
In summary:
- I'll investigate that some regulations about drone uses for fishing in Argentina. (but I think I use that at lonely beaches, such as Faro Querandi Natural Reserve for example)
- Phatom 4 is not designed for this use, I'll see another models such as Matrice 600 Pro for example that support many load height.
2021-2-8
Manu P4P Paris
Flight distance : 136483 ft
apart the fact that this kind of fishing is almost always forbidden, P4 can transport a 1kg payload..but motors/battery will be very stressed and the flight time will be quite reduced.
I tested it with other things attached, even lighter and everything was quite hot after the flight.
2021-2-18
