P2V no telemetry data and camera tilt. Video works
3014 10 2014-12-29
nsxthao
My Phantom Vision, decided to stop displaying telemetry data on the app and I cannot tilt the camera using the app.  The video and camera features all work fine.  I think this happened recently after I updated the app. Since I get no telemetry data I cannot use the ground station feature either. Anyone else have this problem?  What part did you replace?
I have all the latest firmware updates for the main controller, receiver, transmitter with the 3.6 software assistant.  I also have the latest update for the camera.  Is there any updates for the battery or the wifi extender?
2014-12-29
DJI-Autumn
China
2 possible reasons:  the Main Controller lost its binding or the Central Board communications failure.
Have you ever try to rebind?
2014-12-29
nsxthao
Do you mean to rebind the camera to wifi extender? or rebind controller to phantom vision?
Are the green and white wires on the camera cable the wires that send the data to the camera?
Also I have ordered a new main board in case that is the problem.
Thank you for your help!
2014-12-30
DJI-Autumn
China
nsxthao Posted at 2014-12-31 13:16
Are the  ...
Rebind the camera to Extender.
P2V's camera has separate Video Downlink and wifi module so there is no need to use cable for data transfers.
Hope I understand you correctly.
2014-12-30
nsxthao
I will try to rebind camera to extender and report back.
I was talking about the white cable that plugs into the camera. On the main board the connecter has 4 wires. Red, black, green and white.  I assume the red and black provide voltage to the camera, and the green and white send data from naza to camera.  I wanted to test these wires to make sure I don't have a broken wire inside the insulation.
Happy New Year!
2015-1-1
nsxthao
I rebinded the camera to extender. I am still having the problem. Here is a screenshot.
2015-1-1
nsxthao
I can get the pic to link https://docs.google.com/file/d/0B0ILxZB2nwhQUVB5UlN6eFdVT1E/edit?usp=docslist_api
2015-1-1
Gerry1124
Try putting the display on your phone to a lower setting.
2015-1-1
huntarr
I get the same problem same times. Galaxy tab s
I reboot the tablet. I feel it's a software issue not a hardware. I can still get ground station when this occurs.
2015-1-1
tracy.langlinai
This was happening to me intermittently. The culprit was the white cable that connects to the camera. I changed it and all has been well ever since. Good luck.
2015-1-3
knight.vance
I had the exact same problem. Two week old phantom. Suddenly no battery data, no SD card, no position telemetry, no GPS count. I could see the live video, and the Phantom flew properly.
I removed the Vision app from my phone and reinstalled it- solved the problem completely
2015-2-19
