kln
The flight simulator works with the Mavic 2 controller (bought 2021, firmware updated to the last version) and you can access quite a lot of training modes, but it is not straightforward. I use Windows 10, Simulator downloaded and installed a few weeks ago. I may have installed a driver and/or moved a .exe file as it is mentioned somewhere else (nothing that cannot be found easily online).
I then use kyalami's method explained above to launch the simulator and connect the RC, using a USB to micro-USB cable (initially bought to charge an older phone and Kindle).
In the simulator, check the various modes : skills training, free flight, entertainment. In each, use a combination of W, S, A and D to move into the different modes and landscapes offered.
Notably in Skills training, the racing/time trial/tunnel run modes works, but when you fly it the drone seems locked in Sports mode (fun and useful, but maybe not best for beginners). I didn't try everything, there may be more things working.
In the settings, the Mavic 2 controller appears, but when I fly I seem not to be able to change from the default Phantom controller. That may be the reason that some controls listed in the settings for the Mavic 2 controller don't seem to work. Controls that work are the sticks and the gimball wheel, which is sufficient for getting the hang of flying. Use C to change view mode and V sometimes to change drone mode. |
