sbarton
Flight distance : 877110 ft
BEN D Posted at 4-27 03:27
I think you need to do some research on whether the V2 goggles and the new remote work with the air unit (I think they don't, not sure, don't take my word for it)
As far as drone frames there are some prety solid carbon frames espacialy the bangGOD 5" from catalyst machineworks (it will break but you need to try, also somewhat heavy 140gr ). From what I could find online most of the BNF acro style drones are like pre built PCs (meaning you can make something yourself that's cheaper and more robust)
The V2 Goggles do work, the controller does not. This is my 4th DJI drone (P2V+, P3P, MA, and FPV) but first FPV/acro drone. It's a lot of fun, but want something I can push the limits more without worrying about losing $800 in a small crash. I'm leaning towards the Eachine Viswhoop at $260. No way I could put together something for that price as you said. It has the CaddyX HD instead of DJI FPV air, but best I can tell the only difference is the size/weight/cost of the CaddyX is less, but does not have onboard 1080p recording like the DJI FPV Air does. I don't plan on putting a camera on whatever freestyle drone I get so the onboard video would be nice, mostly due to not having to worry about reduced quality when the signal drops. Video transmission range and quality is supposedly the same.
