DJI Digital FPV System HDMI Output Tutorial
26086 19 2020-4-26
Jonatan.C.N
Flight distance : 170627 ft
So it's finally there! After DJI Digital FPV System is updated to v01.00.05.00, HDMI output can be enabled when used with a DJI Smart Controller(01.00.0750.). You can follow the steps below to set up your system.
Preparation before Use:
1. Separately connect the parts of the DJI Digital FPV System (Air Unit, Remote Controller, and DJI FPV Goggles) to a computer, run DJI Assistant 2 (DJI FPV series), and then update them all to v01.00.05.00.
Download link for DJI Assistant 2 (DJI FPV series): https://www.dji.com/cn/fpv/info#downloads
Connect the DJI Smart Controller to DJI Assistant 2 For Mavic, and then update it to v01.00.0750.
Download link for DJI Assistant 2 For Mavic: https://www.dji.com/cn/smart-controller/downloads
2. Make sure that the DJI FPV Goggles and Air Unit can receive signals as normal, and that the goggles can display image transmission pictures.
Connection Steps:
  • Connect the DJI FPV Goggles to the DJI Smart Controller with a USB-C cable. (The smaller connector of the cable connects to the Type-C port of the DJI FPV Goggles, and the larger one connects to the USB-A port of the DJI Smart Controller.) After properly connecting the DJI FPV Goggles to the DJI Smart Controller, open the FPV Live app, and the real-time image transmission pictures will be displayed on the DJI Smart Controller. 3.png 2.png
  • Then connect the DJI Smart Controller to a display screen (such as a monitor) with an HDMI cable, and the real-time image transmission pictures will be shown on the display screen.
Note: After connecting the HDMI cable to the DJI Smart Controller, the screen of the DJI Smart Controller can be turned off by clicking the power button (this will not affect the HDMI output on the display screen). If a live broadcast lasts for a long time, the DJI Smart Controller can also be used while it is charging.
Precautions:
  • After switching the screen display ratio (between 4:3 and 16:9) in DJI FPV Goggles, it is necessary to unplug and reconnect the USB cable.
  • If the display screen is black and shows no picture, first check whether the DJI Smart Controller can display pictures as normal. If not, check the connection between the DJI FPV Goggles and DJI Smart Controller (by restarting the devices or reconnecting the USB-C cable). If the DJI Smart Controller shows pictures as normal, try to restart the app, and then plug the HDMI cable back in again.
  • If the app exits to the background and shows no picture after the USB cable or HDMI cable is pulled out and reconnected during use, try to restart the app and plug the USB cable and HDMI cable back in again. (Before restarting the app, it is recommended to unplug both the HDMI and USB cables first, and then individually plug the USB cable and the HDMI cable back in again).
2020-4-26
Giammi
Flight distance : 847795 ft
I really hope they will find some solution to get HDMI out of the USB-C port. The solution you explained is not practical for me and doesn't work for those not owning a smart controller.
2020-4-27
Pixels with ALT
Does it display AV video for those running the URUAV analogue mod?
2020-4-27
Tangaroa
Chile
Congratulations!!!, great news for those who have Dji Smart  Controller. In my case, have a beautiful and expensive  Crystalsky, can you please tell me where can i find  the FPV Live app for my monitor, thank you very much in advance!!
2020-4-27
Smarkus
Flight distance : 4245 ft
Finland
I've downloaded the latest version of DJI Assistant 2 For Mavic and there is no firmware v01.00.0750 available. What should I do? I have the goggles and really would like to try it out with my Mavic 2 Pro.
2020-8-14
Vu Hoan
Vietnam
I hope the DJI FPV Goggles can connect to the DJI 4 Plus Pro the way Smart Controller does. Possible?
2020-9-16
throneoffarming
South Korea
Why the hell didn't you make HDMI IN?
That's a feature that even goggles under 200$.
2020-9-24
fans0b293311
Thanks for the tutorial. I've got this working with:
  • Goggles firmware 1.00.060
  • SmartController firmware 1.00.0820
(well, working as well as can be expected given the bug in the SmartController where the video will not show up and requre some magic sequence of rebooting the SmartController and the Goggles which sometimes restores video, see this thread: smart controller no image display).
I notice that there is no OSD information output to either the SmartController screen or to the HDMI output, do you guys see this as well? Is there any way to get the OSD (both standard DJI OSD and custom OSD that I am feeding into the FPV air unit) to display anywhere but on the Goggles screen?
2020-10-12
A J
Flight distance : 14754314 ft
Very cool - thanks for sharing
2020-10-13
mc54
Flight distance : 1030 ft
Here is how you can connect a $30 secondary screen when flying analog:
Step 1: turn your secondary screen's power switch
Step 2: hold down the channel search til it locks on your channel
Step 3: there is no step 3
LOL
2020-10-13
djiuser_85ANHKviqFKT
mc54 Posted at 10-13 06:04
In step 3 you watch ANALOG video. LOL
2020-10-15
trica de
Flight distance : 1062090 ft
to be honest.... its a Android device running a software called FPV LIVE so why can this software not be in the Android Store or Apple Store. Simply I would add my Phone to the USB connector of me goggles and thats it !
2020-10-24
geoffz
Flight distance : 1941322 ft
Useless redundant piece of overpriced kit for those that ALREADY possess a controller!  DJI...needs to come out with an AFFORDABLE monitoring solution!!!  For Christ Sake...Do it!!
2020-10-26
bjoern79de
That can't be DJI's honest. I need to buy an "adapter" for $600+ to get HDMI out?!
2020-11-1
Lossius FPV
Smarkus Posted at 2020-8-14 10:33
Dji FPV goggles are for FPV drones, and are not compatible with Mavic, Phantom, or any Dji drone, except for the not yet released Dji FPV drone.
2021-1-13
Lossius FPV
Vu Hoan Posted at 2020-9-16 00:48
Not possible, they're not compatible.
2021-1-13
DroneJunkieQc
Flight distance : 1015679 ft
Does this work for V2 Goggles and DJI FPV ?
2021-5-11
Bezik
Flight distance : 420646 ft
2021-5-11
fans79782605
Flight distance : 5281804 ft
Does smart controller work with fpv goggles v2?
2021-5-31
CR3
Flight distance : 5872635 ft
I’m not seeing any OSD info which is a problem here in australia it’s the only legal way we can fly.  Any idea how to view the osd info?
2021-10-9
