Artifacts on video
1716 15 2021-5-23
RiffSkill
Flight distance : 329347 ft
Hello!
On the new out-of-the-box DJI Mini 2 quadcopter, artifacts appear in the form of waves when shooting video.  I noticed (but this is not certain) that they appear approximately in the second half of the video and only once in each video when shooting a long video, for example, a 15 minute video.  If you change the view dramatically (for example, quickly lower the camera down with the Fn button or apply digital zoom on your phone, they disappear without a trace. Tell me what is the reason for this and can I do something about it? Latest firmware, last DJI FLY. There are no filters on the lens. The lens is clean.
Attached a link to the video. At 45 seconds, I show how to get rid of artifacts:
https://youtu.be/rAoSUOMQ__M
2021-5-23
JohnDG
Flight distance : 1097270 ft
Malaysia
Maybe an SD card which is too slow.
Check if the SD card you are using is on the recommended list. https://www.dji.com/mobile/mini-2/specs
Eventually try a different memory card and format it on the drone itself.
2021-5-23
RiffSkill
JohnDG Posted at 5-23 23:33
The memory card meets the performance requirements.
2021-5-23
Return it for a replacement,  thats not right.
2021-5-23
Hello there RiffSkill. I am sorry for the trouble this has caused and thank you for reaching out. Can you please try using a different recommended microSD card on your DJI Mini 2 to see if the issue will still persist. If the issue persist I would recommended for you to contact our DJI Support Team at https://www.dji.com/support or contact the seller for further assistance on this matter. Again I am sorry for the trouble and thank you for your understanding.
2021-5-24
RiffSkill
I don't quite understand why this might be a memory card issue. While shooting, I see these artifacts also on my smartphone in FPV mode ... If you change the view, the artifacts disappear. Could this be a software issue that could be fixed by flashing when an update comes out?
2021-5-24
JohnDG
Malaysia
RiffSkill Posted at 5-24 00:40
A defective SD card has influence on all electronics.
I am using exactly the same card. The used type is ok.
You can try with another sd card, but if the problem remains contact DJI for replacement.
2021-5-24
RiffSkill
2021-5-24
RiffSkill
There are no artifacts on the video from the memory card!
2021-5-24
wateroftyne
Flight distance : 764797 ft
Is your SD card legit? So many fakes out there.
Worth checking just in case.
2021-5-24
CemAygun
Flight distance : 810 ft
Philippines
RiffSkill Posted at 5-24 08:03
If the video on the memory card is clean, and you see these only with the video cache on the phone; than I guess your phone is not fully compatible with the fly app.
2021-5-24
JohnDG
Malaysia
if the video on the memory card is ok , then you could have interference with the video signal or a incompatibility problem with the smart phone you are using. See that you also close other apps that might take too much resources on your phone.
Also might consider to put your phone in airplane mode to stop wifi, bt, lte and other transmissions. The electro-magnetic signals from your phone might influence the controller too.
Lots of wifi signals in urban area might disrupt the signal too.
2021-5-24
D.K.777
Flight distance : 9810 ft
Ukraine
Greetings. I have the same thing happens sometimes. You can see this artifacts only on the mobile phone screen while you are flying. Artifacts can appear rather you record video or not. Overall, the recorded video is clean. DJI Team, please look closer at this problem. Thanks.
2021-5-24
RiffSkill
D.K.777 Posted at 5-24 23:44
Do you have an Apple device with iOS? One of those who responded on another forum had the same problems with an Apple tablet with an iOS operating system. Perhaps this bug is taking place with Apple devices.
2021-5-24
D.K.777
Ukraine
RiffSkill Posted at 5-24 23:59
I use Android device. I always turn on the "airplane" mode while flying. No matter if i fly far or nearby, this issue can happen. Maybe that artifacts are based on some interferences...
2021-5-25
RiffSkill
D.K.777 Posted at 5-25 06:14
Thank you all for your answers.  It was decided to leave it as it is.
2021-5-25
