Gifted0n3
![](https://forum44.djicdn.com/data/attachment/common/65/common_11_usergroup_icon.png) lvl.2
Flight distance : 87454 ft
hi all. i am a reseller of dji products in south africa. i also offer the service to my clients to do product setup for them. once they have made a purchase i would open the box with their permission and do the firmware updates on the drone the controller and all the batteries. Then before activating the drone i would calibrate the imu the vision sensor and also do a compass calibration. then a 1st flight is done to ensure that all calibrations was successfull and that the drone operates as it should. if any issues are found i as reseller send it back to my supplier as an out of box failure and needs to be exchanged. this past week is have sold 7 mavic air 2 and 3 air 2S's as well as 4 enterprise duals. with all 14 of these drones i could not calibrate the vision sensors once. i contacted online product support to see if there is a quick solution or if there is something i did wrong but support was no help at all. they told me that there is something wrong with the drone. the more i tell the operator on the other side so what he is implying all 14 drones i sold this past week was faulty and all had exactly the same issue.
dji assistant 2 for mavic gives an error stating that the moment i want to calibrate the vision sensors on three different models there is an aircraft movement error. it restarts the calibration and simply will not calibrate the vision sensors. now i have been selling dji drones now for 6 years and effectively repaired dozens of drone in the past 4 year. out of warrentee i might add, successfully. never had any issues like this. as this is a first i tried speaking to support online but with no luck.
can any one here give light on the issue as i honestly thing the issue is with the dji assistant 2 for mavic software. and yes i have tried it on mac os and windows. nothing works. basically i can only use the dji assistant 2 for mavic to do a firmware update. you can not calibrate vision sensor with the controller.
any help will be much appreciated otherwise i need to return 14 drones at once to dji.
