Cant install 1.4.4
1229 24 2021-7-30
JCDM
Flight distance : 102156 ft
Bolivia
I can't install version 1.4.4. when I change the battery it goes back to version 1.4.8. What am I doing wrong?
2021-7-30
DJIAndrei
Flight distance : 906555 ft
Romania
When you change the battery in the drone the app goes back to the previous version?
2021-7-30
JCDM
Bolivia
DJIAndrei Posted at 7-30 11:07
When I change the battery installs 1.4.8. Popup message something like "initiating resources" and then when i look the versión a 1.4.8 is installed
2021-7-30
Ph3onix
Flight distance : 2341886 ft
Hi, what phone do you have?
2021-7-30
JCDM
Bolivia
Huawei p20 pro
2021-7-30
Ph3onix
Ok first of all have you had the battery updates?
2021-7-30
JCDM
Bolivia
Ph3onix Posted at 7-30 12:51
Yes, was updated
2021-7-30
Ph3onix
JCDM Posted at 7-30 13:08
Yes, was updated
OK you have to completely uninstall dji fly
1 / before deleting dji fly you must clear the cache and delete the data then you can uninstall dji fly
2 / With your file explorer you on the main storage of your smartphone and you delete all the DJI folder.
3 / You can install DJI FLY 1.4.4 no more problem with version 1.4.8
2021-7-30
JCDM
Bolivia
Ok thank you very much.
2021-7-30
Ph3onix
You're welcome
2021-7-30
Hi there. We're glad that you already manage to isolate the issue with the help of our fellow DJI Pilot here Ph3onix. Please don't hesitate to reach us if you have other inquiries or concerns. Thank you for your continued support!
2021-7-30
JCDM
Bolivia
DJI Paladin Posted at 7-30 20:08
Well, after doing everything Ph3onix said it didn't work. After connecting the controller again the pop-up window "initiating resources" appeared and was updated back to version 1.4.8
2021-7-30
Ph3onix
JCDM Posted at 7-30 20:13
Hi, do you think to disable auto update in the settings of DJI Fly?
2021-7-30
Ph3onix
I have just redone the whole procedure on my tablet and on my smartphone (Asus ZenPad 3S 10 and Xiaomi redmi note 8t) on one I did not delete the DJI folder and on the other yes.
On the device or the DJI folder and still present I went back to DJI FLY 1.4.8
The other or the DJI folder has been deleted remains in 1.4.4
So you have to delete the DJI folder on the device's storage, after clearing the cache, delete the data and uninstall the app.
2021-7-30
JCDM
Bolivia
Ph3onix Posted at 7-30 22:40
I have deleted the entire DJI folder even delete it from the deleted files folder. When I run the application everything goes well, activate the account,  update the safe flight, uncheck the automatic update. Then I exit the program, run again and turn on the mini that is where the program exits and when I run it again is when it is updated to the 1.4.8
2021-7-31
JCDM
Bolivia
I did another test, when I turn off the mini and change the batteries version 1.4.4 is maintained (3 batteries) . When I turn off the control and reconnect is when it is upgraded to version 1.4.8
2021-7-31
kyalami
Flight distance : 14068337 ft
JCDM Posted at 7-31 09:45
If you disable the auto update in the settings of DJI Fly. it should not be able to update again.
2021-7-31
JCDM
Bolivia
kyalami Posted at 7-31 10:27
its disabled
2021-7-31
kyalami
Sorry, then I do not understand why it still is upgrading to 1.4.8. Hope someone else can assist you with this.
2021-7-31
JCDM
Bolivia
Connecting the control is when it is upgraded to the 1.4.8
2021-7-31
Ph3onix
It's strange, I wonder if this does not come from the settings of your smartphone (Huawei have a different operation on some app)
Can you do the test with another device to see if it's a problem with the smartphone or the drone?
2021-7-31
JCDM
Bolivia
Sorry, right now I don't have another smartphone... is possible reset the controller firmware?
2021-7-31
Ph3onix
JCDM Posted at 7-31 11:32
so we have to hope that DJI will quickly release an update of this trash can from 1.4.8
2021-7-31
JCDM
Bolivia
I just got back, flew until I almost exhausted the 3 batteries with 1.4.8, thank God no problems, all ok. Thank you all for your help
2021-7-31
Ph3onix
great for you that you had no problem
2021-7-31
