bjr981s
Flight distance : 139698 ft
DJI Gamora Posted at 11-23 02:10
Hi, there. Sorry for the misleading caused. We are very concerned about your feedback on our products, and we also hope to continue to provide services to you.
Could you tell me the firmware version of DJI Action 2?We'd like to forward your situation to the relevant engineer. Thank you.
Hi Gamora,
Thanks for you assistance in understating more about the issue.
The Firmware is V01.01.0510. It is the firmware version that was requested by Mimo on activation.
These test runs gave me the following results. All were done after 5 -10 minutes in the freezer at -18C this was to cool after the battery charging the gets the unit very hot. I will measure temp for you with my laser temp unit I use to test heat of ESCs and Motors.
4k 50fps. tested multiple times.These are the durations of the video when it cancels record due to heat.
1: 4:24 Camera Only 3840x2160 Codecs dbgi, AAC, HEVC, Colour Profile HD (1-1-1)
2: 4:01 Camera Only 3840x2160 Codecs dbgi, AAC, HEVC, Colour Profile HD (1-1-1)
3: 3:52 Front Screen 3840x2160 Codecs AAC, HEVC, Colour Profile HD (1-1-1)
4: 2:54 Front Screen 3840x2160 Codecs AAC, HEVC, Colour Profile HD (1-1-1)
2.7K 30fps Flicker bad. Due to 30fps
1: 5:18 + 1:09 Camera only 2688x1512 Codecs dbgi, AAC, HEVC, Colour Profile HD (1-1-1) Split across 2 files.
2: 0:28 Camera only 2688x1512 Codecs dbgi, AAC, HEVC, Colour Profile HD (1-1-1) Allowing to cool to cool to the touch. No Freezer.
3: 1:53 Camera only 2688x1512 Codecs dbgi, AAC, HEVC, Colour Profile HD (1-1-1) Allowing to cool to cool to the touch. No Freezer. Stopped due to low battery.
1080P 50fps. Fully charged battery 5 min in Freezer no flicker
1: 10:43 + 5:22 Camera only 1920x1080 Codecs dbgi, AAC, HEVC, Colour Profile HD (1-1-1) Split across 2 files. 10% Space left warning then immediate overheat. But did get 16:05 record time.
Also please note if you leave on File Transfer as it charges it overheats and the connection keeps dropping to the computer. So SD card and Internal storage keeps flickering in and out.
Let me know if more information or testing is required.
Unclear to me why it drops the dbgi codec when recording to the SD card on the front screen.
Also the battery charge level will cause a power off if the Camera requires charge e.g. 80% and the Front Screen battery level is low it gives low battery warning and then powers down even if the camera itself has plenty of battery..
Just as I finish this post the Memo App has just advised that new FW is available for the Action 2.
Is this update to correct any overheat issues? I will test and advise again once tested.
Cheers
