Possible flyaway situation
681 15 2021-12-2
Captgeo
Flight distance : 1195472 ft
So I had a "fly-away" this morning.  Weather was clear morning with less than 5 knot wind.  Wanted to catch the sunrise but was plenty of daylight.  Waited for "updated home point" then took off.  raised it up and noticed the gimbal was slightly off and not level with horizon.   All of a sudden the drone just took off forward and backwards at high speed.  I was able to counter the movement finally and brought it under control.  Did some testing while it was still up and felt comfortable flying around again.  The flight logs show movement but no stick input for a few seconds.  I also got a high wind alert but wind speed was as stated.  I included link to flight log if anyone has a chance to look at them.  Coincidently, I got a firmware alert right after I landed.
EDIT: Just to clarify, the firmware update was not the one that came out right after launch.  I did that before I flew for the first time.  This was an all new update.  Might have been the Fly app update but the aircraft reset and the message was "Aircraft firmware updated"
https://www.phantomhelp.com/logviewer/995963DU4LYY4SXLQIMD/
2021-12-2
JJB*
Flight distance : 12566335 ft
Amazing data in your log!
After takeoff and some climbing your M3 accelerates and fly away....
Distance from 1 meter to 45 meter, BUT without your input on the RC controls your M3 returned back, see the distance line in my chart.
Well, that is if the LatLon data is correct.
You had even time to take 2 pictures in the fly-way  ;-)
Need a better look, but i think with only 9 satellites, the signals not good enough to keep in stable in position.
Compass data looks oke to me.
cheers
JJB
2021-12-2
Captgeo
JJB* Posted at 12-2 09:29
I was taking pictures in the AEB setting, I think that may be why the shots were taking during flyaway.
2021-12-2
Suren
Flight distance : 13498560 ft
I read some where on here about issues with the drone when a guy was taking pictures in AEB as well similar to your problems. Hopefully Dji addresses this issue. I have stayed away from that setting since I read it.
2021-12-2
JJB*
Captgeo Posted at 12-2 09:31
It is a serious error, the horizotal speed alomg the x and y axis zero, while M3 is speeding away!
First picture taken when already moving away.
If selecting the AEB is the reason for this....nah, do not believe that. But if, i would return my drone for this.
cheers
JJB
2021-12-2
Harkco
Flight distance : 288658 ft
Have you had any additional occurrences since updating firmware?
2021-12-2
NGC
Flight distance : 50003 ft
2021-12-2
Captgeo
NGC Posted at 12-2 11:16
Did you hear this sound while it was flying away?
https://www.youtube.com/watch?v=MK6TXMsvgQg
LOL, now that you mention it yea!    My heart jumped for real though.
2021-12-2
Captgeo
Harkco Posted at 12-2 11:07
Just got back from flying.  New battery instead of the same one.  I shot everything in  AEB mode again.  Did not have any issues this time.  You can bet I was a little nervous and was ready for anything.
2021-12-2
Harkco
Captgeo Posted at 12-2 12:16
I had a similar issue while vacationing in Florida over Thanksgiving week.  Flew it all week with no issues in the air.  Last day it developed a mind of its own and was drifting with no input from controller.  At the time it was about 600 ft over the ocean and I about had a small aneurysm.  About 30 seconds later it was back to normal.  There was very little wind.
2021-12-2
Lucas775
Flight distance : 50642090 ft
How many satellites did you have this time before take off?
2021-12-2
Captgeo
Lucas775 Posted at 12-2 16:08
12 at take off this time.
2021-12-2
Hello there Captgeo. I am sorry for the trouble this has caused and thank you for reaching out. Since this unfortunate event happened to your DJI Drone, I would recommend for you to contact our DJI Support Team at https://www.dji.com/support?site=brandsite&from=nav for further assistance with regards to this matter. We will do there best to help you and give out the best resolution for the said issue. Again, I am sorry and thank you.
2021-12-2
GaryDoug
Flight distance : 1264639 ft
OK then. I am not flying the M3 until after the update. In the meanwhile I will use my very capable (and now unexplainably obsolete) Mavic 2 Pro. I am hanging on to this one; it may become in huge demand soon ;-)
2021-12-2
I thought the M3 had fly away cover as standard from DJI as one as you'd bound the craft in the fly app.
2021-12-3
Buzzyone
Flight distance : 4647913 ft
DAFlys Posted at 12-3 00:30
It does as part of the warranty, you just need to bind the controller to the drone in the Fly App. Not to confused with linking which is different.
You would still be droneless while the investigation is ongoing.
2021-12-3
