Why does the Yaw restrict forward motion so much?
589 13 2021-12-17
CloudVisual
Flight distance : 97545420 ft
I'm having a hard time understanding why DJI have made it so that when the Mavic is hard Yawing left or right, the drone will not fly forwards when given that stick command. It just circles and no matter if its 10% forward or 100% forward stick input, the drone just completes a very small circle of the exact same size.
Very useless in my opinion and not flying like any of the other drones they make, which of course makes the drone different to fly and behaves slightly different in the air, especially when making banked turns.
I would like to see a setting to turn this off in the next update, it's not right to restrict the forward speed in a yaw.
I encourage people to try this to see what I mean:
Yaw hard left or right so the Mavic 3 is spinning on the spot and then give a forward input. Watch the size of the circle, now increase the forward input and the circle does not change.
Typically any other drone would have an ever increasingly large circle until you hit 100% forward throttle and this allows for large banked turns. This drone just dances around in a small little circle irrespective of the forward input.
2021-12-17
Are you 100% yawing?  If so perhaps back it off a little.
2021-12-17
CloudVisual
DAFlys Posted at 12-17 04:53
Yep, but none of the other drones do this, so why this one now..
I'm out flying this to put the hours in, but I'm finding that it doesn't fly like the others due to this. The reason is that it slows down when I start a banked turn, so there's no chance of keeping up top speed and banking at the same time.
2021-12-17
Yaros1
Flight distance : 21307762 ft
Try to disable Obstacle Avoidance and try again, maybe the drone is slowing down because it can't scan obstacles and wants to make sure there is nothing in the way.
2021-12-17
CloudVisual
Yaros1 Posted at 12-17 05:35
…I never fly with obstacle avoidance on.
2021-12-17
MM M3 Cine
Mine does this too. Extremely irritating.
2021-12-17
Flight distance : 10186312 ft
I have to agree with you, it flys a bit like a Scabby Dog with an itch. It definitely needs optimization and although I have tamed it a little by just using it and trying to set exp to help I’m still having problems. Don’t get me wrong I love what the drone can do image wise but it doesn’t fly anything like the Air Air2s or M2P or Zoom. Much work needs to be done.
2021-12-17
GaryDoug
Flight distance : 1264639 ft
Keep your old M2p...I am.
2021-12-17
CloudVisual
GaryDoug Posted at 12-17 22:05
Yes, at the moment the crop on the 10bit, 360 photosphere, no landing protection and natural flight controls all trump the M3.
I am keeping a firm grip on my M2P for now.
2021-12-18
CloudVisual
I have now further tested this and I can only begin to say that the Yaw restricts movement in ANY direction.
Once the drone begins to Yaw even slightly from a standstill, 1-100% stick input has the exact same input.
This means that the drone cannot make a large circle motion to circle a point of interest, if the left and right sticks are in the following position. (Mode 2)
This feels as if the drone is in some sort of beginner mode and it's stopping me from being able to fly the drone in a natural way. DJI needs to change this, it's not right.
2021-12-22
Nicodema
Flight distance : 90259 ft
CloudVisual Posted at 12-22 06:00
Well that's truly bizarre, since we've seen loads of examples of people shooting manual large orbits. If they had the behaviour you describe, it'd be impossible. Finding it hard to reconcile the two. You say that you get this partial lock out for any amount of yaw, even a tiny amount? Originally you were talking about 100% yaw.
Do you have any sample flight footage?
2021-12-22
CloudVisual
Nicodema Posted at 12-22 06:10
The problem is that I can do large orbits in flight, it seems to allow it, but you have to be moving left or right to begin with and then introduce the yaw to make the orbit. If you Yaw first then fly left or right, it will fly in a small circle.
2021-12-22
Nicodema
CloudVisual Posted at 12-22 06:13
Ah, I see. Definitely a bit odd. Hopefully something DJI can iron out.
On the plus side, that IS a peculiar way to start an orbit, so it's relatively unlikely to impinge on normal flight. I guess that's probably why their testers didn't spot it. So, good to bring it up.
2021-12-22
CloudVisual
The problem here is that DJI are altering how the drone behaves in the air depending on the current state of the flight. Unless you're flying in a cinematic/tripod/POI mode, the sticks should behave EXACTLY as they have been programmed to in the gains settings.
With these settings at the moment, it's very difficult to make a wide rising, circling jib shot - something I do a lot.
Another problem to throw on the pile. I'm not impressed with this drone so far
2021-12-22
