Motors Won't Start
1051 10 2015-12-10
donstouder
Flight distance : 25571 ft
Seemingly all of a sudden my motors won't start. I did the basic IMU calibration and got a message saying no calibration needed. One thing I did notice though on the RC is that the power light (not the three lights) to the right is yellow not green. I believe it is generally green. Assuming it should be green, what would that indicate? I have the P2V+ v3. All of my firmware is up to date. Also I did see a message/button that said Reset BTU. I did not really understand it, so I did not click on it.
Any thoughts?
Thanks in advance.
2015-12-10
PanamonCreel
Mexico
From the P2V+ manual: Remote controller Power LED Status --> Solid Yellow ---> Remote controller joysticks calibration error, need to be re-calibrated
Connect to your TX with the RC Assistant software and do the calibration routine to fix the issue
2015-12-10
DJI-Patrick
Hi ,
Please calibrate your RC in the RC Assistant  . And re-calibrate the RC again in the PT2 Assistant .
2015-12-11
quanthonytrang
Flight distance : 419980 ft
There could be a number of things:
You might need to rebind the controller.
A faulty S1/S2 toggle switch that leaves it in permanent Failsafe.
Could be a dead receiver board inside the phantom.
2015-12-11
donstouder
quanthonytrang Posted at 2015-12-11 06:50
A faulty S1/S2 toggle sw ...
How do I rebind controller? Also, is there some indication that it is locked in Failsafe? I redid the IMU basic cal, which seemed to work ok.
Is the yellow light on the controller I referred to indicative of a problem?
Thanks for the reply.
2015-12-11
donstouder
donstouder@ca.r Posted at 2015-12-11 08:57
How do I rebind controller? Also, is there some indication that it is locked in Failsafe? I redid  ...
Thanks to al of the repliers. I will go back through process again.
2015-12-11
DJI-Ken
Flight distance : 1515312 ft
Here is the link for linking the controller to the Phantom, page 19, I think this is your issue.
http://dl.djicdn.com/downloads/p ... _Manual_v1.8_en.pdf
2015-12-11
PanamonCreel
Mexico
donstouder@ca.r Posted at 2015-12-12 00:59
Did you do the Stick calibration yet as mentioned before ( that's what the yellow light on the TX indicates)?
This is a calibration done with the Transmitter connected to your computer and using the RC assistant software to do the calibration.
This is different from the IMU calibration you did connected to your Phantom with the Phantom assistant software.
2015-12-11
donstouder
Thanks to everyone had to recal the RC unit. Light turned green an motors now start. I know, RTFM. I did but that was several months ago. :-)
2015-12-11
roy
Glad you got it Don, happy flying.
2015-12-16
DJI-Dave
donstouder@ca.r Posted at 2015-12-11 11:32
Thanks to everyone had to recal the RC unit. Light turned green an motors now start. I know, RTFM. I ...
Good to hear you have it all sorted out now.
2015-12-16
