Mini 2 lost connection at only 400 meters :(
6752 14 2022-3-21
djiuser_yQsLxoqh0U5y
Flight distance : 169990 ft
Portugal
Hi guys.
I was trying some follow modes on Litchi and all went well.
After that I was using DJI Fly app getting a friend on his bike and the drone lost connection at only 400 meters.
I opted for the mini 2 instead of the SE exactly for this not to happen.
Viewing the fly data I can see RC Signal strong just after getting weak next second and losing the link.
I downloaded the flight data and uploaded to phantomhelp.com but I cannot see the rc signal info.
It was a new urban area with no construction nearby.
kinda frustrated with a 10km drone not making even a 400 meter stretch...
Nuno
2022-3-21
Pleomax
Flight distance : 835725 ft
HI
You are in CE region so range is only 6Km. 10 Km in FCC region.
Post a share link to your Phantom Help log here for analysis.
2022-3-21
nmb1970
Portugal
Pleomax Posted at 3-21 11:44
HI
Even with 6Km, 400 meters is a bit short...
https://www.phantomhelp.com/LogViewer/10MM0QRHY9DLZGB8K50Z/#
2022-3-21
LoveYou
Flight distance : 19819324 ft
You Flight 10m from the road?
Try more Altitude and tell me....
You need to learn the basic...
2022-3-21
nmb1970
Portugal
LoveYou Posted at 3-21 12:03
It's my first drone and yes I was trying low altitude to test follow modes on Litchi and then switched to the DJI Fly app.
https://youtu.be/LFNSG5te3KQ
But is altitude the cause of lst connection at only 400m?
I'm always ready to learn
2022-3-21
JJB*
Flight distance : 12686732 ft
Had a look at your log.
Easy to see what happend, at disconnect your mini drone was flying at minus -15 meter height.
Uh, yes, see the chart.
Left side of the lower chart = take off position, right part is disconnect position.
So you lost signal as your mini2 was not in line-of-sight for the radio signals.
cheers
JJB
2022-3-21
Pleomax
nmb1970 Posted at 3-21 12:20
Hi again
Yes, altitude to low for good RC reception. Flying below level of antennas will give poor signal.
2022-3-21
nmb1970
Portugal
Got it!
At least I'm glad it's my fault and not the drone. My stupid mistake.
2022-3-21
nmb1970
Portugal
Guys you really know this and I was at fault.
2022-3-21
JJB*
nmb1970 Posted at 3-21 12:39
Got it!
HI,
Learning all the time!
BTW  the most important check before take-off is to check the compass heading in the map view FlyApp and compare this heading with the actual heading of your drone.
If not the same ; do not start a flight.
Many happy landings,
Cheers
JJB
2022-3-21
OneSnark
Flight distance : 652231 ft
Random question:  What happened after you lost connection?      I believe the default is that the drone does a "Return to Home"?    Did that function work?
I have been very cautious with my unit. . . . I have noted some signal strength degradation in the 300M to 400M range . . . but I definitely have not been in mood to "push it", and have always turned around when I have less than 5 bar strength.
2022-3-21
JJB*
OneSnark Posted at 3-21 21:15
Connection loss only for about 7 seconds, so no RTH as that is started after 11 seconds.
DJI RTH function does work great!, so do have your trust in that.
cheers
JJB
2022-3-21
nmb1970
Portugal
JJB* Posted at 3-21 23:46
Exactly. As soon as I lost connection, I went a bit ahead and got back the connection.
2022-3-22
Landey
Just to add ...
Old German saying: "HF geht seltsame Wege ..." - High frequency works in mysterious ways ...
The higher a frequency, the lower it's ability to penetrate solid objects, like hills, houses, even trees. Sometimes it still works, but that's because of more of less random reflections. So you can never rely on that, thus try to keep a real visual line of sight to your drone all the time - especially if it's further away.
Something more to keep in mind in an urban environment:
Structures, buildings, all the like. A single obstruction might cut your connection.
Plus: Wi-Fi everywhere. If you're in a densely populated area, chances are high that Wi-Fi devices flood all channels available to your drone.
Plus: Vehicles. I see an older motorbike in your video. Sparks from the spark plug (especially with older vehicles) often cause wild disturbances in the high frequency spectrum which also might interfere with your drone's wireless connection.
The wireless coverage of your Mini 2 is great and very solid - but it also cannot defy the rules of physics.
2022-3-22
Hi there. Thank you for reaching out and we're sorry for the trouble. We're glad that you have already managed to isolate the issue with the help of our fellow DJI Pilots here in Forum. We strongly recommend to fly the aircraft in an open space away from cell towers and any possible interference to avoid disconnection. Thank you for your valued support.
2022-3-22
