JJB*
Flight distance : 12717890 ft
Sean-bumble-bee Posted at 4-16 20:55
Maybe I am midunderstanding what you mean but if, for example, the drone is moving horizontally 1.5m above flat ground, in fog etc. that is thick enough for the VPS to think it the drone is 50cm above a surface and the pilot applies down stick, how is the drone suppoesd to know that the VPS sensed height is a FALSE reading?
Flying above flat surface at 1.5 meter in thick fog than if the VPS sensor sense 0.5 meter (thus false reading) than it will enter forcelanding when down stick is applied.
VPS sensor will never know that it senses FALSE, no extra logic behind this sensor...
Thus....
1 - OPTION to disable/enable downward sensor is needed, let the remote pilot decide to use or not to use this feature.
2 - Automatically disable sensor when flying baro-height higher than....x meters. [ x = user set value ]
This will solve the problem flying high while the donwward sensor sense false 0.5 meter, this false reading for whatever reason.
3- Flying low with any x speed in any direction : automatically disable landing protection and refuse to lower craft below 0.5 meter (as in autotrack mode)
If user applies down stick than prompt the pilot if he wants to land....so no more unwanted forcedlandings ! if pilots wants to land than enable landing protection.
cheers
JJB
