Mini 3 Pro Micro SD Card fitting and removal.
123Next >
19521 115 2022-5-17
As I discovered early the Mini 3 Pro Micro SD card is recessed,  so unlike the Mini2 it needs to be pushed in further than I can do with a finger nail,   being caught out in the field I found the only thing I could use was another Micro SD card, not even a key would work.  But now I'm home and need to remove the card to get the footage I can't reach deep enough into the slot to eject the card.
Seems that the Mni3 should have come with a fitting tool.  But in the mean time what are people using to fit and eject their cards?
Edit:
For anyone with access to a laser cutter,  attached is the design for the tool ready to cut.
SD Eject Tool.svg.zip
685 Bytes, Down times: 46
2022-5-17
Lobster
I used to have this issue when I had the original Air and I was hopeful we'd moved on from that irksome little joy
2022-5-17
Lobster Posted at 5-17 09:22
Ive just designed a little tool that I will laser cut in the morning,   but the corner of an old credit card seems to work for me quite well.
2022-5-17
MySky
Flight distance : 364902 ft
Cool idea @DAFlys.
That issue has already been mentioned in one of the youtube tests.
Somtimes it is an advantage being a female drone pilot, so i will not have that issue.
2022-5-17
MySky Posted at 5-17 10:40
Cool idea @DAFlys.
Somtimes it is an advantage being a femal drone pilot, so i will not have that issue.
The other half with long nails did it but struggled compared to the mini2
2022-5-17
DowntownRDB
Flight distance : 1722 ft
DAFlys Posted at 5-17 09:28
Nicely designed tool DA.  I think I'll just go simple and use the edge of a credit card.
2022-5-17
Blériot53
Flight distance : 6260935 ft
Necessity - the mother of invention
Amazed that DJI did not address this issue before launch.
2022-5-17
DowntownRDB Posted at 5-17 11:39
Problem is we don’t carry them here these days.  Apple Watch is all I need 99% of the time.   I carry an Emergancy £10 note in all my bags along with a face mask and my drone registration card.
2022-5-17
Blériot53 Posted at 5-17 11:49
Yes.  I thought these issues were a thing of the past.
2022-5-17
Blériot53
DAFlys Posted at 5-17 11:54
Maybe you should quickly patent and market your removal tool
2022-5-17
Blériot53 Posted at 5-17 11:57
Nah.  I will laser cut one in the morning and if it works I’ll share the files for free here.
2022-5-17
Blériot53
DAFlys Posted at 5-17 12:04
Bound to be popular if it works
2022-5-17
DarthSLR
Flight distance : 1846716 ft
How about using the tip of the propeller?
2022-5-17
DarthSLR Posted at 5-17 12:07
Lol.   I didn’t have a screw driver handy to remove it.
2022-5-17
Blériot53 Posted at 5-17 12:06
I’m sure I won’t be alone with the problem.
2022-5-17
Blériot53
DAFlys Posted at 5-17 12:10
Grow a long fingernail like that Indian Guru
2022-5-17
DarthSLR
Wait, you need a screwdriver to remove the props from M3M? Not just push and twist, like all the other  Mavics?
2022-5-17
DarthSLR Posted at 5-17 12:14
All the mini’s have screw on propers.    Saves weight I guess.
2022-5-17
Blériot53 Posted at 5-17 12:13
SHMBO’d has long nails.  I know as she frequently stabs/slices me with them and she really struggled to eject it.   She did it in the end though.
2022-5-17
All minis have split props connected by screws . Again its a weight issue. This drone will seem like a toy if you haven’t had one before, but its really the tech your buying.
2022-5-17
Blériot53
DAFlys Posted at 5-17 12:19
Can data download be achieved with a cable, or does the card have to be extracted to transfer pics and video.?
2022-5-17
Blériot53 Posted at 5-17 12:21
You can transfer full res photos through WiFi ti ipad/iphone android etc. I think for video you need to remove disk.
2022-5-17
Blériot53
hallmark007 Posted at 5-17 12:24
OK thanks.
It just seems such an elementary oversight, to make it so inaccessible.
2022-5-17
I’ve not tried.   But DC Rainmaker said it overheats just sitting whilst on.
2022-5-17
If it’s like the mini2 you loose the EXIF data if you do that.
2022-5-17
Ps.  It’s not a Mavic anymore.  They technically dropped that from anything lower than Mavic 3.
2022-5-17
Blériot53
DAFlys Posted at 5-17 12:31
Another minus point there
2022-5-17
Blériot53 Posted at 5-17 12:33
I’ll try it in the morning and see what happens.  It’s worth a go.
2022-5-17
Blériot53
DAFlys Posted at 5-17 12:37
2022-5-17
DarthSLR
hallmark007 Posted at 5-17 12:20
oy vey, that bad, huh...
2022-5-17
djiuser_alwS1UbVcYCA
it gives you a warning because no airflow is going through the drone.  it does not mean you can't interact with it.
2022-5-17
DarthSLR Posted at 5-17 13:57
When you see it fly you begin to realise how important this drone is and just how good it flies.
2022-5-17
DowntownRDB
I use Samsung Pay a lot but then some stores don't have it and others have it but the system may be down so I always carry the credit card as a back-up.
2022-5-17
DarthSLR
hallmark007 Posted at 5-17 14:27
I believe you. Just not going to buy it now. Scaredy cat, you know... Got burnt too hard on M3...
2022-5-17
DarthSLR Posted at 5-17 14:44
I think it might need a couple of updates anyway , its not going to be perfect out of the box. More beta testing fun ahead.
2022-5-17
DarthSLR
hallmark007 Posted at 5-17 14:47
I'm still not sure if I really need it. Carrying both drone and RC is not something I'm willing to do on my light hikes, and if I'm carrying a bag/backpack I might as well put something like M3 in it, which has better cameras and flight capabilities). True, 60 degrees up is a nice feature, but I would not really use it. So, again, don't see immediate benefits in getting one, for now at least...
2022-5-17
Hello there DAFlys. I am sorry for the trouble this has caused and thank you for reaching out. I will forward these information to the designated DJI department for evaluation. Thank you.
2022-5-17
Flight distance : 2354357 ft
I would use my nails unless ive bust them all lol I do carry a Samsung sim car ejection tool so prob that or another memory card, but I've never not had a nail to use as yet for memory cards, i am answering this because ei have a wifi camera with this problem and the body is in the way on one side making it even harder with my nails :/
2022-5-17
Blériot53
djiuser_alwS1UbVcYCA Posted at 5-17 14:06
That may be, but overheating whilst stationary is not something I have noticed in other drones I have owned, during downloading data to the computer by cable for example.
2022-5-17
DowntownRDB Posted at 5-17 14:44
Since covid the rollout of the terminals here really accelerated,  even car park machines take them now.    I was in a store pre covid where the machines went down and they just closed for the day,   Ive not seen it happen since,  but I do usually have an emergency note just in case.
2022-5-17
123Next >
