Inquiry about RTH
595 6 2022-6-8
danyrr
Flight distance : 2527425 ft
Good morning to all;
I have verified that doing the RTH, the drone does not turn to be able to take some shots while he returns home. This with the Mini 2 if it could be done. Do you know if this is the case or if I'm not doing something right?
Greetings.
2022-6-8
Geevo
Henrik says the same thing here about not being able to turn the drone while in RTH mode. Time stamp start didn't work so it is at 22:15
So seems normal but I haven't tried myself.
2022-6-8
Blériot53
Flight distance : 6260935 ft
Once RTH has been initiated, the prime objective of the drone is to return to the Homepoint by the most direct route (straight line) and at a pre-determined altitude above HP ( Provided you set one).
You can vary the altitude with the control stick during RTH, but the drone will not deviate from dead-ahead from what I've found.  The surest way to achieve what you want, is to cancel the RTH when the drone reaches the desired location, do your manoeuvering and shot-taking, then re-initiate RTH to resume the path back to RTH.
2022-6-8
TheBoy
Flight distance : 28958264 ft
None of the DJI consumer range allow this, apart from the Mini 2.  The Mini 2 did not have the function at launch, so its possible DJI may add it.
In the meantime, try practicing doing it manually - with time and effort, you can get pretty close, but it does need muscle memory to manually keep it on a straight course.
2022-6-8
TheBoy Posted at 6-8 05:15
You spend most of your time around here giving out wrong information. Almost all dji drones allow this Mavic 1 Mavic 2P Mavic Zoom Air1 Air2 Air2s Mini2 Phantom 4P etc etc….
2022-6-8
TheBoy
hallmark007 Posted at 6-8 05:30
I should have been more specific, and said currently available. Apologies for that.
I don't have an Air 2/2S locally to try, but the user guide for both (P15 for Air 2S and also P15 for Air 2) specifically states the orientation cannot be controlled during RTH.
But of the remaining current Mavic series, SE can't, Mini 3 can't, Mavic 3 can't (unless it came with that big F/W just over a week ago).  The SE and Mini 3 are on the latest available f/w.  Mavic Mini is still available in the UK at some outlets, so should include that as well.  It can't.  These I have just tested myself, just now.
I know its not current, but just did a quick test with a Mavic 2, that cant either, unless there is a setting in the app - it was a quick test with a flat battery, so could have missed something on that one.
2022-6-8
Mobilehomer
Flight distance : 18150351 ft
Not the 2S, I tried it last night. Maybe the new firmware. I will try in a little while
Edit: Just got back in testing the new firmware. NO, the only input while RTH is gimbal up/down and altitude. No yaw or roll.
2022-6-8
