MrJayd
Flight distance : 1717133 ft
DJI Stephen Posted at 6-13 19:11
Hello there MrJayd. I am sorry for the trouble this has caused and thank you for reaching out. May we please know what is the the version of the DJI Fly application that you are using please for us to be able to isolate the issue? Kindly please fly your DJI Mini 3 Pro to a different location with less interference to see if the issue will still persist? The DJI drone might have picked up magnetic interference on the ground, and you took off from close to a buildings with rebar concrete metal objects on it. In addition, please make sure that the antennas are pointed toward the aircraft for optimal transmission. Thank you.
1.6.1
And just flying above trees or water in the other direction. No building or magnetic interference around. But like I said my old mini 2 used the get 3 times the distance flying the same areas. |
