Is DJI going to atleast acknowledge the signal issues???
123Next >
6580 108 2022-6-21
mkdp.photos
Flight distance : 717218 ft
Is DJI going to atleast acknowledge the signal issues on the Mini 3 Pro???
I'm in Canada (FCC) and got mine a week or so ago and have flown it every day since then basically, and the signal is just so inconsistent and unreliable
Constant signal drops unless you're literally 100m away with DIRECT line of sight to the drone (before you bring up VLOS, Canada does not have VLOS laws on mini drones).
I got so fed up that I decided to buy a Mini 2 from Costco just to test it and see if that had any better signal and oh my god, the Mini 2 can hold a 5 bar signal at up to 2000m away, and beyond that still hold a 4 bar signal. It's just so much more reliable and consistent. It can go places that I can not even get close to with the Mini 3.
Just today I was at a lake and was parked in a nearby school parking lot. The Mini 2 was able to go over to the lake 500-700m away and even get as low as 20-25m in altitude at that distance and still hold enough signal for me to take pictures. But the Mini 3 had constant 2 or less bar signal at that distance, and I could not get any lower than 50-55m without completely losing signal and RTHing.
Even though the Mini 3 takes better pictures than the Mini 2, the Mini 2 pictures came out better because I could maneuver to have better composition and framing and get closer. Dissapointing.
I thought Occusync 3.0 was supposed to be better than 2.0 so clearly there's something wrong with the Mini 3 Pro
But the worst part is that DJI is not even acknowledging this isssue. I've spoken to support multiple times over the past two weeks and every time they say they are not aware of any signal issues with the Mini 3 Pro.
So tell me then DJI, should I just return this drone since it seems to be working as intended in your eyes?
2022-6-21
Bigplumbs
Flight distance : 620164 ft
This has been discussed so much on here of course they know. Some have issues others don’t I suspect there is a faulty batch and they are trying to decide what to do about it.
The range distances you are getting point to a hardware issue/somthing faulty in the controller or drone. Have you tried your mini 2 n1 controller with the mini 3
2022-6-21
mkdp.photos
Bigplumbs Posted at 6-21 22:06
I have not, will try that tomorrow.
I suspect it won't make a difference though as a bunch of youtubers have already shown that to be the case.
It's just mind blowing that the Mini 2 for half the price is so much better in this regard.
They need to atleast make a statement that they are looking into it, because I don't want to be stuck with this $1300 (CAD) toy when my return policy ends.
2022-6-21
Ive been flying my Mini2 back to back with the Mini3 now for 250miles and the range is almost identical between them,   in some flights the mini3 has actually better,  the video feed is noticeably smoother on the Mini3 too.
2022-6-21
DJI Wanda
Hello, there. Sorry for your inconvenience. Would you please export the logs of both the remote controller and aircraft?
We would send it to our engineers for further analysis.
Please also tell us the information below:
1) The date and time for the connection issue.
2)Choose multiple logs in which contain the connection issue.
Please compress them and upload them to Google Drive or Dropbox. We will send you instructions on how to export logs.
2022-6-22
Bigplumbs
DJI Wanda Posted at 6-22 01:26
That is not what was meant and you know it
2022-6-22
I find it very strange that those suffering bad signal would go out buy another drone to simply prove there is something wrong with their drone. Ocysync signal O3 is an improvement on O2 and most people have said this, Ocysync is the signal for your video transmission .
Because most people are not having issues with signal I would recommend instead of buying more drones that you return your drone under warranty and tell dji you want one that is working like most people have. You’re waiting for a fix to radio transmission that has never happened before that I remember.
2022-6-22
Skyzlmt
Flight distance : 2191946 ft
Bigplumbs Posted at 6-22 02:15
genuinely curious... I dont understand your comment of "that is not what was meant and you know it"
Person complains about an issue.
A company rep responds, shows interest, and asks for logs so an engineer can review..
I was amazed to see that.  Have you ever been on other vendor forums?  No one from the companys jump in.
So what more are you expecting? What did the DJI rep do wrong?   Genuinely confused
2022-6-22
nosnoop
Flight distance : 237953 ft
Even though you are in Canada, double check that you are in FCC mode.
Occasionally, my Mini 3 would stay in CE mode until I restart the drone.
I am really having no issues with range while flying in GTA.
2022-6-22
Cauffy
Flight distance : 36752 ft
DJI will never openly admit there's a problem, what they will be doing is analysing data from the software/hardware perspective and see if there are any issues they find and then make change through updates...
2022-6-22
mkdp.photos
If you're going to need me to do half your work for you then atleast  give me instructions on how to do it
2022-6-22
TheBoy
Flight distance : 28958264 ft
Your experience matches mine, its more of a problem with consistency of signal.  Difference being I already have a Mini 2, and also still have my Mini 1.
I think there may also be a firmware problem for FCC models, as there are some tips online about preventing the drone getting a GPS lock too early to stop it getting CE transmission spec.
I suspect the poor positioning of the antenna is probably at the root of the problem, due to the Mini 3 not having any landing legs.  Thats not going to be good for diversity, in the same way a Mini 2 cannot retain the same signal as bigger Occustnc 2.0 drones like the Mavic 2 or Air 2.
2022-6-22
The Saint
Flight distance : 5902228 ft
if you are in an urban area and there's a guy in his basement playing call of duty, it's just interference. /s
2022-6-22
mkdp.photos
TheBoy Posted at 6-22 06:12
Seriously it's embarrassing how much better of a signal the Mini 2 gets compared to this $1000 drone
They should be all over this with official statements and hotfixes but nothing, they don't even acknowledge that there is a problem.
2022-6-22
chillibadger
Flight distance : 233064 ft
mkdp.photos Posted at 6-22 06:24
So just like the mavic 3 gps issues.  Pushing products to market and then fixing issues in an agile way like programming it seems rather than have a final tested product.  The only issue with the approach is if it can’t be fixed via firmware
2022-6-22
mkdp.photos
chillibadger Posted at 6-22 08:16
And in that case, you'd be stuck with a defective product, dishonestly advertised and out of $1000
2022-6-22
Xtropy
Flight distance : 12625 ft
Try this. Something is wrong with drones in Canada where we're stuck in CE mode
2022-6-22
mkdp.photos Posted at 6-22 08:24
You won’t be stuck with anything if you return it. Or at least send your flight logs .
2022-6-22
mkdp.photos
Xtropy Posted at 6-22 09:06
Yeah Ive seen that but the fix no longer works. DJI patched out the fix to make sure the problem still occurs.
2022-6-22
fans41164975
Flight distance : 17510 ft
mkdp.photos Posted at 6-22 09:52
You have to slow down Satellite acquisition.. Just but your controller over de drone when power up.. you should stay in FCC mode
2022-6-22
mkdp.photos
fans41164975 Posted at 6-22 10:51
Ive tried it, doesnt work
2022-6-22
Bigplumbs
Skyzlmt Posted at 6-22 03:55
When you have been on here a while you will learn that the Admin do very little other than post pointless standard text
2022-6-22
Bigplumbs
Huge parts of the world use CE mode all the time you speak as if it is impossible to have good signal with CE mode
2022-6-22
mkdp.photos
Can we get any sort of update or communication from DJI??? It's like talking to a brick wall
2022-6-22
GLOBAL HAWK
Flight distance : 287841 ft
What signal issues? My drone works as expected.
2022-6-22
nosnoop
mkdp.photos Posted at 6-22 12:26
The only way to get DJI support is to contact DJI support.
This is a community forum, you will get no answers here.
2022-6-22
The Saint
nosnoop Posted at 6-22 13:44
not only that, it's a public forum.  no reputable company should post such internal business on a public, community forum.  i challenge anyone to find another type of forum where the manufacturer regularly "admits" to problems before they find solutions or at least begin to address the issues.  imagine if autel could create an account here, and then ask dji if there is a problem with their o3 communications link and get the answer.  this forum is not a diary.
2022-6-22
mkdp.photos
The Saint Posted at 6-22 14:11
Ok so why then does DJI not tell me when I contact them in private that they are aware some customers are experiencing issues with their range (well documented by now) and that they are looking into it?
2022-6-22
nosnoop
mkdp.photos Posted at 6-22 14:15
Not sure what you are looking for.
"Signal issues" probably involve an umbrella of potential causes which may or may not apply in your specific situation.  For example, the FCC/CE bug would not apply to any users in Europe.  And issues affecting CE mode would not apply to you.
So getting DJI to "admit" it would not help you to solve your problem.   You do your part by reporting to DJI support, and I am certain that their team would be working on it to resolve any issues they could find to improve the signal range.
Keep asking DJI to "admit" the issue in the community forum would not help either.   You can ask support directly if you want them to "acknowledge" this issue if it makes you feel any better.
2022-6-22
The Saint
refer you to nosnoop reply.
2022-6-22
mkdp.photos
nosnoop Posted at 6-22 14:59
The main thing I want is confirmation on whether firmware will fix this or not
If its a firmware fix then fine, but I don't want to be here in a month with DJI still completely ignoring the issue like it doesnt exist
2022-6-22
DJI Wanda
Hi, there. Sorry for your misleading.  There are so many factors associated with transmission. As we mentioned above, would you please export the corresponding logs for us so that we can send them to our engineers to further analyze your issue?  Kindly note that we would treat the issue case by case. Also, we have replied to your PM. Please check.
2022-6-22
DJI Wanda
mkdp.photos Posted at 6-22 05:12
Hi, there. Sorry for any misleading. We have sent you an instruction through PM. Please copy the link and download the file.
2022-6-22
alex_markov
Flight distance : 39878160 ft
Bulgaria
I use DJI drones for 5+ years and never saw DJI admitting a problem
2022-6-22
Xtropy
Bigplumbs Posted at 6-22 11:16
Are any of your posts helpful Bigblumbs? I am trying to help people, you just troll. Stay out of range conversations and keep your "opinions" to yourself unless you have anything helpful to offer.
2022-6-23
Xtropy
It still works, you're mistaken and there has been no patch (last firmware caused quicker satellite acquisition so you need to block the signal). On the second reboot, bring your drone into your house or car when you power it up and go out into the open area after 2-3 minutes.
2022-6-23
Bigplumbs
Xtropy Posted at 6-23 04:27
Yes many and Nope I will post as I feel. Who made you Queen
It is simple you have either got a Dud or you dont know what you are doing either way those that are happy with their Drones can post as they see fit
2022-6-23
Skyzlmt
Bigplumbs Posted at 6-22 11:14
thanks. I get what you are saying... "lip service"  and correct, while I've had the acct here a while I dont follow along much.
2022-6-23
mkdp.photos
Xtropy Posted at 6-23 04:30
How long do I keep the drone in the car on second boot? I tried it for 30 seconds or so and it still didnt work
2022-6-23
Xtropy
mkdp.photos Posted at 6-23 06:16
2-3 minutes and it only works after a second reboot. There is a full conversation about this issue and workaround here: https://forum.dji.com/forum.php? ... D776%26typeid%3D776
2022-6-23
123Next >
