SD card folder naming and other file questions
1095 8 2022-8-29
fansfbd2311f
Flight distance : 384698 ft
I noticed that the drone only puts 999 files in a folder before creating another folder and beginning the file numbering from 1 again.  This is somewhat annoying as I don't know why file names need to be reused and makes for more complicated file storage archiving.  But that said, what happens when you fill up an SD card and start a new one?  Does it start with the original folder name and number, and file names back to 1?
Secondly, when filming in 4k30, I am noticing that video files are broken down into 5:30 segments.  Is that default behavior, or is this a setting?
Thanks,
2022-8-29
If you have formatted the card in your computer after copying the files to your computer, the numbering wil continue from where you left off.
If not it will start at 001.
It's not about time, it's about filesize and that's completely normal.
2022-8-29
fansfbd2311f
Labroides Posted at 8-29 02:57
I did not format my first card on my computer, but are you saying that if I format the new card on my computer the drone will not reformat it and will continue with the numbering sequentially?  What about the folder naming convention?
BTW what type of formatting should I use?
Thanks,
2022-8-29
fansfbd2311f Posted at 8-29 03:11
I'm saying that if you format the sd card (in your computer) after copying the image files, it will continue file numbering from where it left off.
If you format in the drone, it will restart numbering at 001.
The folder naming conventions will be unchanged.
The default quick format in A windows computer is fine.
2022-8-29
fansfbd2311f
Labroides Posted at 8-29 05:15
How does the drone know if I copied the files off the first card?  How does it know not to start renumbering?  I guess that's where I'm confused...
2022-8-29
fansfbd2311f Posted at 8-29 05:36
I've explained how it is.
Don't bother with those questions.
2022-8-29
Beta5K
Flight distance : 196880 ft
How does the drone know where you left off after formatting the card through the computer?
Is there something that doesn't get deleted in the card during the formatting?
2022-8-29
Sean-bumble-bee
Flight distance : 15997 ft
Beta5K Posted at 8-29 10:09
The drone carries the name of the last image in its memory, same as a DSLR does, except perhaps when the card is reformatted in the drone. In those circumstances it appears that that 'memory' is deleted. You can however reset the numbering scheme of a reset 'counter' by coping the last image shot by the drone back onto the card and then put the card back into the drone. If the last name of the lasy image contained the number xyz then the number of the next image shot will be 1 greater than that.
2022-8-29
Sean-bumble-bee
If you do ever get to 999 +1 then use something like bulk rename utility to add a leading zero to the number part of your old images wherever they are stored BUT NOT on a memory card that will be used in the drone so the for example xyz_001.jpg becomes xyz_0001.jpg and xyz_999.mp4 becomes xyz_0999.mp4. Then, when saving 999+ imagery to wherever, once they have been copied/moved to wherever add a leading 1 to the the number part of the name etc. etc.
2022-8-29
