Bussty
Flight distance : 359705 ft
SPLflyer Posted at 9-13 22:35
Good morning, Andrew, thanks for your kind appreciation. I was surprised myself by the good result. The subject is certainly nothing great, but it perfectly meets the criterion of maximum difficult stitching requirements. It didn't go completely flawless either. To be honest, I had to do some slight retouching on the bark of a tree trunk that had been stitched a little bit out of place ;-). But that was quickly done with the clone stamp. I took the vertical shot directly prior to the panorama. This shot took the position of PANO0003.DNG during stitching, which I removed completely from the process. There would have been duplicate, slightly shifted information in that area otherwise. However, the vertical shot completely filled the space – there were no blank spaces. May be you can consider this in your own experiments as well.
Cheers, Bernd
Hey Bernd
Yes firmly of the view it will be luck to get a 100% perfect stitch if the drone is as close as it was in your sphere but as you rightly say is easy enough to retouch.
I think the process you have described is what I have been using on some distant spheres with success but not close in yet.
I do have to pinch myself to be reminded to match colour balance, iso and shutter speed with the first vertical single shot and the DJI auto sphere as they store their own last settings. This is one little nuisance step that hopefully DJI can eliminate. Would be quite nice to just push that big white button and know it was all taken care of |
