Buzzyone
Flight distance : 4647913 ft
Every time you switch systems you need to re-bind with the aircraft. It should also do this using the buttons.
Make sure you have updated the firmware on both systems, connected to the fly App to make sure you have the latest versions, the goggles contains 3 firmware versions, confirm with the forums that the goggles etc report the correct version for the system you are using (Avata, FPV & FPV System)
With your Avata, while you are connected to the fly app and the internet, go into “profile” then “device management” and select Bind (don’t remember the exact wording) make sure all your devices are powered up and linked before doing this. This step ensures the controller, aircraft & goggles are all bound to your DJI account. Only then do you have flyaway cover! Once you have done this the message in the bottom right of the goggles should disappear.
It’s rather confusing because you bind the aircraft to the goggles but you also bind the system to your account, it would have been better if they had different names for each process.
