KeithM6
Flight distance : 450400 ft
kcw Posted at 10-24 07:23
Did you really mean you are using 7.1GB of internal? Assume a typo?
I did not notice that my crashes were only when a plane is in the area. However, will test with that to confirm if it's the same problem. Of course, I will need some planes to cooperate I guess!!
No. There are 7.1GB of internal memory available, (not used), as I'm using the SD card. In my case, each time a manned aircraft is detected, DJI FLY crashes. As soon as the aircraft is no longer detected, the unit returns to normal operation. |
