The engines guard is a cause of an error
995 19 2022-11-23
VLSOL
Flight distance : 74449 ft
Hello Everyone!
I've bought the engines guard for the protection from water and anything, but when i installed it i have seen an error like "Can't check engines, please, call to support". One important thing, my engines don't moving during the switching-on with the short sound. I checked, nothing to touche my engines. So, when i removed it - all is ok. What wrong? What i do not properly? Anybody use this accesories?
2022-11-23
Elendil
Flight distance : 458904 ft
Philippines
Were you using the screws that came with the cover?
2022-11-23
frankymusik
Flight distance : 27904331 ft
Good to know!
2022-11-23
DJI Wanda
Hello, there. Sorry for your inconvenience. May we know when you take off those accessories, does the error message disappear?
2022-11-23
Nees
Flight distance : 80991 ft
I would rather like to see a picture from your drone when they are installed!
2022-11-24
VLSOL
DJI Wanda Posted at 11-23 23:36
Hi, yes. You’re right! All is working properly right now without these guards.
2022-11-24
VLSOL
Nees Posted at 11-24 01:37
Ohh, sorry, maybe I will repeat it later, but I’m an engineer (my work) and I strongly did it by guide I mean a placement (L1 L2 and etc…)
2022-11-24
VLSOL
Elendil Posted at 11-23 21:24
Yes, they’re a little bit longer. Am I right?
2022-11-24
Killerbee
Flight distance : 64820 ft
VLSOL Posted at 11-24 09:47
I think the longer screws are a little bit too long and are touching the motors.
2022-11-24
VLSOL
Killerbee Posted at 11-24 09:54
Ye, good idea. I worried that guards may fly off from engines and broke propellers. I will test with an original screws.
2022-11-24
VLSOL
No, I have tried right now and original screws are not enough for this. Can’t spin (
2022-11-24
Killerbee
Why do you want them anyway? They seem pretty useless.
2022-11-24
DJI Wanda
VLSOL Posted at 11-24 09:44
Then, we would recommend you take off the third-party accessories.
2022-11-25
Bob Brown
Flight distance : 4209662 ft
DJI Wanda Posted at 11-25 00:47
... and this ladies and gentlemen is the EXACT answer I was thinking.
It's obvious that they will do more damage than good. Consider the heat build up also; motor damage.
2022-11-28
djiuser_oF6L4g3TjIAF
I bought the motor guards also and mine did the same thing I had to cut the screws down about 1/16 of an inch three threads four threads only and they work fine now no overheating
2022-11-29
And when you install them make sure they are centered and not touching none of the sides of the motor itself or you will get a motor error
2022-11-29
KLRSKIR
Flight distance : 28650751 ft
It's just Avata telling you that you don't need motor covers.
2022-11-29
blekmen2103
Flight distance : 202976 ft
Latvia
Я подтверждаю эту проблему. Это происходит из-за длинных винтов которые пробивают провода подключенные к двигателям. Есть 2 варианта исправить эту ситуацию...1) сточить 2мм с каждого винта и  повреждения проводки не будет, НО!!! крепления двигателя будет НЕНАДЁЖНЫМ ! ....2) второй способ самый правильный-  устанавливаем на двухсторонний скотч изнутри по кругу и по центру защиты. При таком способе двигатели крепятся на родные винты, защита не болтается и имеет щель между двигателем и защитой для охлаждения.
2022-12-6
VLSOL
blekmen2103 Posted at 12-6 11:33
С двустр скотчем вариант прикольный, хотя, если отклеится в воздухе будет больно движку
2022-12-6
blekmen2103
Latvia
VLSOL Размещено в 12-6 11:39
С двустрочным скотчем вариант прикольный, хотя, если отклеится на берегу будет больно движку
надо толстый 2мм . у меня проблем нет, стоит плотно, уже летал. Для себя я этот вопрос закрыл. https://forum44.djicdn.com/data/attachment/forum/file:///C:/Users/blekm/Pictures/bloetooz/P_20221118_001342.jpg....https://forum33.djicdn.com/data/attachment/forum/file:///C:/Users/blekm/Pictures/bloetooz/P_20221118_001035.jpg
2022-12-6
