What is the best place to mark your FAA registration code on a Phantom 3?
31816 20 2015-12-31
lexnasser
I just registered my drone with the FAA and I recieved my registration UAS Certificate Number. The FAA site reads that you must mark the number on any and all aircraft before you operate them and that the number must be visible without using tools (You may mark it inside the battery compartment if that is accessible. You may use any method to affix the number that ensures it remains visible, including permanent marker, label, or engraving.). I was just wondering where the best place was to put it on my Phantom 3 Standard. I would like the number to not be visible while still following the FAA rules. I was thinking the battery compartment but I wasnt sure how to place it in there and where to place it without affecting the connection between the drone and the battery. Any ideas?
2015-12-31
nrgwise
Look at your quad, decide where you want it, put it there.  No big decision, no need to ask where the best place is.  The best place is where you decide to put it.  Some people put it in the battery compartment - a small label on the side - thinking it would interfere with the connection is just silly.  Some put it on the leg with a label or permanent marker.  Some put it on the shell.
2015-12-31
skyphotovideo
Flight distance : 311791 ft
I printed all of my information onto a sticker, and then i put it right on top of the DJI logo, then took a spare logo and put it right in front of that
2015-12-31
robkei
I looked in the battery compartment.  It's pretty tight in their and I did not want to cause any issues with the battery (heat, binding, etc.).
I put mine on the rear landing strut.
BTW, I have no issues with registration, at all.  Anything I pilot requires registration (car's, motorcycle's, etc,).
2015-12-31
aburkefl
Flight distance : 78612 ft
On my P3Pro, thre's a very small "ledge" just above where the battery slides in. Using the smallest font available on my P-Touch label maker, I created a label (self-stick) and put it on that little ledge.
As others here point out - it doesn't matter. Put it where it fits.
Art - N4PJ
Leesburg, FL
2016-1-1
todbnla
2016-1-1
BMK1
aburkefl@gmail. Posted at 2016-1-1 10:22
On my P3Pro, thre's a very small "ledge" just above where the battery slides in. Using the smallest  ...
I put mine i the same place, the printed out label fit perfect.
2016-1-1
Flying Poptart
Flight distance : 734577 ft
I bought a set off this guy on ebay and put it in the same spot...I like it.
http://www.ebay.com/itm/30183595 ... =STRK%3AMEBIDX%3AIT
He has lost and found ones also:
http://www.ebay.com/itm/Drone-Lo ... 26sd%3D301835951256
2016-1-15
shawnc
Flight distance : 111762 ft
Battery compartment no need to show everyone.
2016-1-15
Cetaman
Flight distance : 2528264 ft
Aloha lex,
     There are many creative ways, noted in this thread, on how to do it.  In my case, I printed out a column of my numbers in an 8 font with my printer.  Then I cut them out so they would fit on a short strip of half inch 3M invisible tape.  Using a tweezers, allowed me much more control to place the number in the middle of the tape.  I put a number on each of my batteries so when I put them into the P3, the number was in the battery compartment.
     Then I put one just under the Phantom name in the front of the body facing forward just for fun (and on my P2 to).
Aloha and Drone On!
2016-1-16
Cetaman
Flyin'Bryan Posted at 2016-1-15 17:45
Here is the beginning of the end ... Mandatory insurance, and licensing... this will be just the sta ...
Aloha Bryan,
     You can print out a column of registration numbers in an 8 font with a printer.  Then cut them out so they would fit on a short strip of half inch 3M invisible tape.  Using a tweezers, you can place the number in the middle of the tape.  I put a number on each of my batteries so when I put them into the P3, the number was in the battery compartment.
Aloha and Drone On!
2016-1-16
Yep then apply them to the box your Phantom came in.
2016-1-16
Chicago Air Dro
We bought us online from this company they have a video showing how and where to apply your sticker.
This is where we put ours looks like its made to be there.
Some people say put in the battery compartment but how would it fit?
Does anyone know if you can just put it on the battery...Does FAA allow this?
HTTP://faadronedecals.com
2016-1-16
dacofty
Flight distance : 1061345 ft
I used permanent label right under the label from DJI on the under belly
2016-1-16
terrylewis
Flight distance : 3517287 ft
And the FAA Says!
2016-1-16
Frank Biganski
Flight distance : 1343888 ft
I know this is an old post, but I wanted to provide a company I found on ebay that provides some really decent FAA registration stickers, for those as anal as me who could never come to using a Sharpie on their beautiful ride.  For basically $7 bucks, the company provides several stickers, a laminated FAA registration card, free lost drone service, and they shipped within a few hours too!
https://www.ebay.com/itm/Drone-F ... hash=item33c346729c
Frank
2018-1-19
JasonBo
FAA REGISTRATION STICKER BUNDLE
https://www.slickwraps.com/bundl ... obbyist-pilots.html
Click here
Outdoor / Indoor
Laminated & UV-rated to resist fading
Water resistant
Durable & scratch resistant with a matte finish
Easy to apply with residue free removal (if you ever need to remove them, they’ll come off clean)
Customized with your FAA number as well as phone number in case of loss
2018-2-8
Forum Troll
Flight distance : 13235 ft
Thanks for the great template
2018-2-10
SkyBug2
Flight distance : 487566 ft
Forum Troll Posted at 2018-2-10 15:58
You needed a template to do that?  LOL.
2018-2-10
Forum Troll
SkyBug2 Posted at 2018-2-10 17:00
No but it makes it simple
2018-2-15
AndrewCCM
Flight distance : 4738 ft
Piece of paper taped inside the battery compartment.  Works like a charm.
2018-2-15
