Mini 3 Pro - Is Fogging Still an Issue?
5650 39 2023-2-15
Occams Razor
Flight distance : 639327 ft
I'm going to be purchasing a Mini 3 Pro and wanted to know if users have been experiencing any lens fogging.  It looks like the chatter has died down so I'm assuming the problem was limited and affected a very small population.
Thank you for any feedback.
Randy
2023-2-15
Thank you for your interest in our product. During manufacturing, we usually remove the moisture before sealing the lens and ship out products after strictly following the inspection and testing procedure. Please stay assured this phenomenon will not occur. If any issue occurs after receipt of a product, please don't hesitate to reach us. Thank you for your valued support.
2023-2-15
Hi, Randy. Thanks for your interest in our product. During manufacturing, we usually remove the moisture before sealing the lens and ship out products after strictly following the inspection and testing procedure. Please stay assured that this phenomenon will not occur. If any issue occurs after receipt of a product, kindly contact us for help. Should you have further concerns, please reach back here at DJI Forum. Thank you, and have a nice day.
2023-2-15
BodkinsBestPhotography
DJI Tony Posted at 2-15 19:41
You USUALLY do?  So every manufacturing day except Monday and Friday?  Why are there so many people having this issue?
2023-2-15
Suren
Flight distance : 13498560 ft
Yes, I had it almost 5 times in a spate of 3 days but I went from a cold room to the warm outside so that may have triggered it. Still pondering if I should send it back
2023-2-16
Curious why your getting Mini3 Pro when were about 100 days from Mini 4 release?
2023-2-16
DowntownRDB
Flight distance : 1722 ft
DAFlys Posted at 2-16 01:03
I hope you are spot on with the Mini 4 release date.
2023-2-16
DowntownRDB Posted at 2-16 03:43
They've been on an almost yearly cycle for a while now.
2023-2-16
DowntownRDB
DAFlys Posted at 2-16 04:36
True and I hope that cycle continues.  I'm excited to see how much DJI can improve on the Mini 3 Pro.  Would still be nice to have cruise control and waypoints for the Mini 3 Pro.
2023-2-16
DowntownRDB Posted at 2-16 04:41
Ive been doing some tests with waypoints the last couple of days.    Ive long wanted to take the same picture multiple times spread over weeks/months.    Ive experimented with the M2P waypoints and Litchi but none have been better than I could do myself (at least in some scenarios like building site where you can line things up for repeatability).   So far I repeated the same shot 4 times and used photoshop to align the layers.  that and a crop I can get something reasonable from the Mini3 waypoints.   the trick is to be a bit further away than you would compose the shot manually and use hyperlapse + raw/jpg to fly to a spot a take some images and then stop the waypoint mission.
2023-2-16
DowntownRDB
DAFlys Posted at 2-16 04:48
I guess I just prefer the auto mode for waypoints.
2023-2-16
DowntownRDB Posted at 2-16 04:53
Indeed,   just trying to make something work with what Ive got.
2023-2-16
gnirtS
Flight distance : 5712575 ft
SDK may allow sort-of waypoints with virtual sticks.
Its not as accurate but for non precision work its good enough on other models as long as its not too gusty.
2023-2-16
Occams Razor
Haha!  Mainly because I didn't know there is a Mini 4 so close to release date.    I've been very busy so not only have I not had much time to fly but I am disconnected from current updates.  I have $600 in Best Buy credit of which $300 expires in April so I thought I spend the credit on a Mini 3 Pro.   However, your post will cause me to rethink my strategy.
Thanks for the information.
2023-2-16
Pastime
Flight distance : 3395469 ft
I have heard nothing of a mini 4 , just an air 3 possibly sometime in may.
2023-2-16
BodkinsBestPhotography Posted at 2-15 23:02
We appreciate your input. To put it simply, the water vapor will condense on the lens when the temperature becomes rapidly higher. Similarly, our glasses usually fog up in winter when we suddenly enter a room with a higher temperature. However, the fog will dissipate itself when the ambient temperature is constant. Thanks for your understand. We hope you have a great day.
2023-2-16
DJI Tony Posted at 2-16 22:07
The issue described is not fog on the outside of the lens.  It's fog on the INSIDE!
2023-2-16
Vương Sơn
Flight distance : 883320 ft
Vietnam
BodkinsBestPhotography Posted at 2-16 22:56
Ở Viet Nam bị rất nhiều, nên họ chán bán thanh lý với giá rất rẻ. Vì gửi đi hãng để sửa rất phức tạp nhất là máy mua lại từ người khác (không có hóa đơn mua hàng).
Nhưng tôi đã tự sửa bằng cách thay gioăng và bôi mỡ chuyên dùng cho ống nhòm, kính thiên văn. Không có phòng hút ẩm, nên tôi dùng khò tóc để sấy hết hơi ẩm trong cam ra và lắp lại với gioăng mới. OK!
2023-2-16
TonyPHX
Flight distance : 11229610 ft
Although I have had no issues with lens fogging, the reports from other members that I trust tell me that there must be something to it and perhaps your mileage will vary.  If I saw that happening, I would send it back for replacement.
2023-2-16
Occams Razor Posted at 2-16 08:12
Dont get me wrong the Mini 3 Pro is a super little drone but as they have been yearly releases on the mini range it would seem like a good idea to wait a little.
2023-2-16
Pastime Posted at 2-16 08:25
With the yearly releases it would be a safe bet to expect one is coming.
2023-2-16
DowntownRDB
DAFlys Posted at 2-16 05:03
Nothing wrong with that.  At least you have the know how to make it work for you.
2023-2-17
Pastime
DAFlys Posted at 2-16 23:30
I would think it will probably happen.
2023-2-17
Occams Razor
DAFlys Posted at 2-16 23:29
I understand.  The Mini 4 release is not a sure thing but a May release would be aligned with the product cycle cadence.  That's the problem with buying technology products in that there is always something newer and potentially better just around the corner.  I'll be traveling for 3 weeks in March so I'll see what's swirling in the rumor mill when I return.  Thanks for the tip.
2023-2-17
Vương Sơn Posted at 2-16 23:24
If I drop $1300 on a new product I expect it to f**ing work!
2023-2-17
PixelPro
Flight distance : 1205715 ft
That would be great. it's going to be a challenge for them to upgrade the camera for sure (hoping for 1inch like the AIR 2s
2023-2-17
Zhillz
Flight distance : 2914944 ft
It's likely that the majority of fogging complaints occurred during the humid summer months of July and August. However, since it is now winter, it's doubtful that this is still an issue.
2023-2-17
Flight distance : 2354357 ft
Zhillz Posted at 2-17 17:03
Im still seeing them crop up on the Mini 3 Pro groups on FB, one is a UK group and its winter here...
I am yet to see any fogging with mine, although, I do have at least 10 silica bags of varying sizes in my backpack, thats mostly in case it goes in the bag a little damp.
2023-2-17
Pastime Posted at 2-17 08:08
I do too. and if they keep up the year cycle I should be able to get a free one from Argos again.
2023-2-18
Occams Razor Posted at 2-17 10:24
No worries OR.
2023-2-18
DowntownRDB
PixelPro Posted at 2-17 15:17
No doubt it will be a challenge.  Especially if they try to put a larger camera on it as they will still aim for keeping the weight under 249G I'm sure.
2023-2-18
May we know if you are encountering such an issue? Please let us know. We'll be happy to assist you with your concerns. Thank you.
2023-2-19
Billy.RKV
Flight distance : 2922815 ft
Portugal
Yes the fog on this drone model is still existent.
I’ve had several different units, from different manufacture dates, still presenting fog inside the lens.
2023-2-22
Drey. I
Flight distance : 1757375 ft
I dont have it
2023-2-23
djiuser_kKGKnB0FIILK
I had this issue with my mini 3 pro, reported it and sent the unit to DJI. They acknowledged and confirmed the fault. replaced it with a refurbished unit although at the time i was told it was a 'new' unit. replacement arrives and same issue. They now want to have it back to fix/replace/through against a wall..... another week without the drone because they have awful quality control and even worse customer service. Annoyingly i've just purchases a ronin gimbal from amazon - i'll aim to never purchase from them again.
2023-3-13
djiuser_5EX0nJLTThvr
It’s still an issue. Received drone 15/8/23 from DJI
2023-8-15
djiuser_5EX0nJLTThvr Posted at 8-15 12:38
Hello there. I'm sorry about the trouble. Can you please send us a photo or a video showing the issue for further inspection? We are more than glad to help you. Have a great day ahead.
2023-8-18
EingeLVF
Flight distance : 342598 ft
Uruguay
it happens only a few times to me idk why. but here is a good video to fix that if happens to much times to you
https://youtube.com/shorts/h9zyKQa9Ppc?feature=share
2023-8-18
Ranjan
Just happened with for the first time (its first monsoon season for my mini 3 pro) thinking of re seating the rubber O ring with silicon paste. No official Dji repair center in India.
2023-8-21
nazgull
....the thing is, if you're going to open a sealed lense, you need be VERY sure the humdity of the air is very low before re-sealing it...or, it'll happen again...
  "It's cold in the Yukon, but it's a dry cold" Perhaps freezers can be pretty dry places, or perhaps running a de-humidifier a long time in a sealed room might be an idea...
2023-8-21
