DJI Natalia
djiuser_KVdUvcj2gTlo Posted at 4-13 17:32
Thank you Natalia. Can you tell me the if a battery communication error will always result in RC signal lost. It’s strange that the goggles are communicating everything but the battery level and video transmission. And that both the drone and the goggles respond to the controller (changing gimbal angle for example). I have a new ESC installed so I’m assuming the problem is somewhere between the ESC and flight controller. I suppose I’ll have to check that ribbon cable on the flight controller side though I didn’t remove it from the FC.
Does DJI offer tech support beyond recommending to send in for eval and repair?
Hi, djiuser_KVdUvcj2gTlo
A possible reason for the Battery communication error warning is abnormal communication between the battery and the flight controller, leading to an identification failure. In your case, we may need to check your drone and confirm more details.And since your drone has crashed before, it is recommended to send your drone to us for further inspection. it is not recommended to repair it yourself, because it may cause unknown damage and void the warranty. May we know if you have any concerns? you can let us know here and we will see if we can help you further.
We appreciate your understanding.
