RTH being off
844 24 2023-4-13
Shawgod
Flight distance : 5173104 ft
I am having issues where my RTH being off.  Before flight I have the Air2S sitting on a landing pad.  The drone sees at least 16 satellites.  When it tells me that it is good for takeoff I go ahead and takeoff.  I let it hover at most 30 seconds so it can get a good view of the launch pad then I go fly.  When I initiate the RTH it always flys about 6 or more feet from the landing pad.  I have tried to re calibrate the compass, and calibrated the sensors on the DJI Assistant 2 app as well.  I have done everything that I can think of.  I have also cleaned the sensors.
2023-4-13
Mobilehomer
Flight distance : 18150351 ft
First RTFM!!!! Instead of "good for takeoff" wait for "Home Point has been updated". Then fly straight up for 25', this activates Precision Landing. Then it will land within inches.
2023-4-13
Hi there. Thank you for reaching out and we do apologize for the trouble. Can you please confirm if the DJI Fly app indicates that the "Home point is being recorded/updated" after you flew the aircraft as MobileHomer said in the above post? Please have a test flight again and please make sure to have this and see if the issue persists. Please keep us posted. Thank you.
2023-4-13
Shawgod
DJI Paladin Posted at 4-13 18:16
Correct the Home point has been updated.
2023-4-14
Sean-bumble-bee
Flight distance : 15997 ft
If you do not launch the drone in accordance with the instructions to enable precision landing then the drone relies on GPS positioning and that isn't ft perfect.
2023-4-14
Shawgod
Sean-bumble-bee Posted at 4-14 08:51
The drone is launching with the precise instructions, and I am giving it up to 30 seconds once in the air to establish its position and the landing site.
2023-4-14
Sean-bumble-bee
Shawgod Posted at 4-14 13:41
In that case perhaps you could list precisely what you do when launching and include climbs to what heights and what horizontal movements you have the drone make whilst launching?
2023-4-14
Shawgod Posted at 4-14 05:04
Thank you for your response. We will coordinate this with out team. For now, kindly please try to have a test flight in a different location and see if the issue persists. Please keep us posted. Thank you.
2023-4-18
Mobilehomer
No need to give it 30 seconds. Just go straight up 25' before flying off.
2023-4-18
Shawgod
I tried this in a completely different place and it did it there as well.  It was way off this time.  About 10 feet on average.  So I don't know if this is something that I should get use to or I am doing wrong.  I was only giving it 30 seconds as a test to see if it truly needed longer to get the landing point.  But apparently it did not need more time.
2023-4-18
Mobilehomer
Shawgod Posted at 4-18 08:04
When I follow the manual for Precision Landing, mine ALWAYS lands within inches. And this after flying thousands of feet in all directions.
2023-4-18
FabioV
Flight distance : 980066 ft
Mobilehomer Posted at 4-18 08:25
We should also suggest to have a landing pad with a well defined contrast ... If not, the precision landing may not work.
Definitively:
1) Use a landing pad that provides a good contrast versus the background
2) Wait until the GPS icon becomes green
3) Arm the motors and move up gently the left stick
3) Wait until the home point is updated
4) move up the left stick until you reach an altitude of 9m / 27 ft
5) Fly your drone away
At this point, when starting the RTH, the drone should land between few inches from the starting point.
2023-4-18
Shawgod
FabioV Posted at 4-18 08:36
Definitively:
I am doing everything that you have suggested.  I have a landing pad that is bright as hell.  I have tried both sides of the landing pad to see if that makes any difference, and it doesn't.  The GPS icon is green and has almost 20 satellites before takeoff.  The home point is always updated, I don't leave until it is updated.  I get the drone up around 25 ft up in the air and I let it hover there for up to 30 seconds for diagnosing for this reason.  Then I fly away almost 1000 ft then do a RTH.  I do 500 Ft and do a RTH and both distances I get the same landing distance from the pad.
2023-4-18
FabioV
Shawgod Posted at 4-18 09:29
Probably it’s time to open a support ticket.
2023-4-18
Mobilehomer
STOP letting it hover!!! Just fly straight up 25' and then go fly!!!
2023-4-18
Shawgod
Mobilehomer Posted at 4-18 14:47
I am only letting it hover for this test.  I am trying to get it to see the target on the ground to see, if any length of time is needed for it to RTH to the mat.  I normally fly it to 25 feet in the air and then fly it away.
2023-4-19
Sean-bumble-bee
When you fly it away from the home point and then bring it back using RTH does it, once it get's over the homepoint, does it turn to face in the same direction that it was facing when it took off?  Yes or no.
If yes, once it IS facing in the same direction does it then descend?
My M2P/Z behave like that if tehy are going to execute a precision landing, if they do not do that turn then they are going to do a normal GPS landing and it means that the take off did not meet the requirements specified by DJI for precision landing to be enabled.
Open question to everyone, might the Air 2s behave in the same way?
2023-4-19
Shawgod
I haven't noticed the direction that it is facing when it comes down.  When I take it out later today I'll pay attention to this and see what direction it is coming down.  I'll take it out to the field and check on that.
2023-4-20
Shawgod
FabioV Posted at 4-18 14:22
I don't know if there is anything mechanically wrong with the drone.  If there is a DJI representative on here is this something that I should send it back for?
2023-4-20
sduck
Flight distance : 4315098 ft
Another thing to consider trying is not using RTH. I never use it, unless it starts automatically because of some connection interference, and even then I disable it as soon as a connection is re-established. Flying home and landing the drone manually should be something you learn, it's a pretty basic skill, and not hard at all.
2023-4-20
Mobilehomer
sduck Posted at 4-20 07:18
You miss the point. Either he is not following proper procedure or something is wrong with the drone. It is an advertised function and should work as stated. Just because you don't use it doesn't mean others shouldn't. If your new car has a backup camera that doesn't work, even though you never use it, would you want it fixed?
2023-4-20
Sean-bumble-bee
Shawgod Posted at 4-20 05:11
If you are going to test this then, start with the drone on the ground but facing in the intended direction of travel. launch it and fly the outbound leg of the flight in that direction. Once you get to distance RTH it.
This means the drone will do a 180 at the RTH point and, if you launched it correctly, it will do a 180 over the home point. I have checked a couple of youtubes and the Air 2s does seem to behave in this manner but the angle of turn in those videos were small, i.e. the drone took off faceing in nearly the RTH direction.
You could also post the flight log.
If you fly such a flight and it does not do a 180 over the home point then either your launch proceedure is incorrect or there is a problem with the drone or maybe the ground was too dark or in-distinct.
My mavic-2 precision-landed so that the camera was over a coin sized mark on the concrete exactly as I had set the drone on that concrete.
2023-4-20
FabioV
Sean-bumble-bee Posted at 4-19 15:19
The answer is yes. When precision landing is available, the drone lands in the same direction it took off.
2023-4-21
FabioV
Shawgod Posted at 4-20 05:12
If I were you, after following the suggestions from all of us whitout being successful with the precision landing, I would open a support ticket. Activating the precision landing is something really easy: in my case it happened the first time I tried. Nobody in this forum will open a support ticket for you and a DJI representative cannot provide more suggestions than the one already shared.
2023-4-21
Shawgod
I understand landing the drone is a fundamental all pilots should be able to do on their own.  I don't have any issues landing the drone on my own.  I am just trying to get this feature to work properly in case it is needed.
2023-4-21
