Wishlist for software features in future firmware Updates
970 11 2023-6-20
rstewartb
Flight distance : 841276 ft
Having used my M3T for a few exploratory searches and wildlife surveys I thought I would post my current wish list for features in DJI Pilot 2.  Administrators please pass this on to the developers of future updates (firmware up to date as at 19 June 2023).  Apologies if there is already a process or thread for this elsewhere.  If so, grateful to be directed to it.  I would like to see the following:
1        Pinpoints saved when RC Pro Enterprise switched off.
2        Pinpoints exportable as shapefile and csv file as well as kml.
3        Pinpoints importable as kml, shapefile or csv file.
4        Save Raw images (and raw and jpg) option on all cameras.
5        Option to save profiles for RTK custom options to enable switching between ntrip sources.
6        Smart tracking features (at least spotlight equivalent).
My priority would be the last three.  Comments and additions welcome.
2023-6-20
Hi, rstewartb. We'd like you to know that we appreciate your valuable suggestions. We will forward your concern to our related department. After the evaluation of the related department, significant suggestions or requests will be implemented via the firmware update, app update, etc. For any updates, please stay tuned to the latest news on our DJI official website at (www.dji.com) or by checking the Release Notes specific to your product. Thank you for your continued support.
2023-6-20
djiuser_NCjMoze6Z8aM
+1 for RAW and tracking
2023-6-30
Johnnokomis
Flight distance : 13631168 ft
DJI Gamora Posted at 6-20 20:49
These overused, canned responses by admins like this mean absolutely nothing. How are we supposed to believe anything is actually getting forwarded to "our related department" when nothing suggested is ever actually developed? Take this post for example.. OP has 6 great suggestions that are relatively easy to implement. You say they'll be forwarded to this imaginary dev team. Then a week later a new firmware is released that doesn't include a single request from this list.
So that only leaves 2 possibilities going on here..
A. You're lying and nothing is getting forwarded anywhere.
or
B. This related department couldn't care less about what your customers are asking for.
So which one is it?
2023-6-30
Johnnokomis Posted at 6-30 20:42
Hi, Johnnokomis. Yes, we forward every suggestions that is being suggested by the customers but that doesn't mean that it will be implemented automatically. Please understand that everything needs to be evaluated and there's a possibility that not all the requests will be implemented and some might take time. One example of the suggestion that has been implemented was the compatibility of goggles with some of the consumer drones.
2023-7-4
Johnnokomis
DJI Gamora Posted at 7-4 06:44
I like how you slid that goggles compatibility added feature in there. Too bad that has nothing to do with the topic at hand. The M3E/M3T doesn't support any of your goggles and likely never will. Some of what OP is suggesting isn't even added features. Like #1: Don't delete my pinpoints every time the RC is rebooted. This isn't a feature request, this is a software bug that has been reported on for months with no fix in sight. 4 months of firmware development and all that came of it was "optimizing Pilot 2 prompts".  DJI didn't even bother to update the DJI Mavic 3E/3T Known Issues List with this latest firmware update. Which means nothing has been fixed from the last known issue list.
2023-7-4
rstewartb
I note that point 1 above has been addressed in the latest firmware upgrade - thanks.
2023-9-6
Johnnokomis
rstewartb Posted at 9-6 08:21
I haven't had a chance to try it myself but it looks like #5 is also a new feature.
2023-9-6
DRONE-flies-YOU!
Flight distance : 1638323 ft
Pretty sure the ‘real’ answer is unfortunately DJI Pilot 2 is incapable of these features without extensive reprogramming, if you haven’t noticed. I believe this is why there is & won’t be progress in those areas.
2023-9-6
rstewartb
Johnnokomis Posted at 9-6 10:30
Thanks. I will have a look
2023-9-6
Johnnokomis
DRONE-flies-YOU! Posted at 9-6 13:19
You're right but subject tracking has been available on the M30 and M300 platforms for some time now. The term "active_track" can be found inside the M3E's APK several times. Yet it's still not been developed.  "smart_track" is found 38 times.
"aeb" is found 19 times.
"goggles" 14 times.
"video_frame_rate_XX" has 10 different values listed from 24 all the way to 240. Yet we still only have 1 we can use.
All these features have obviously been worked on by DJI but for some reason have been kept from us.
2023-9-6
rstewartb
rstewartb Posted at 9-6 14:18
There are now 5 'configurations' for RTK custom settings, visible when the rtk module is fitted.  My current settings were automatically applied in configuration 1 and RTK works as expected.
2023-9-6
