No Expo settings under Cine mode? DJi Mini 2
1549 10 2023-6-21
RoninOverFlight
I have the Expo setting under Normal flight mode but when i goto Cine mode to calibrate there is no Expo settings for joystick sensitivity.
Is this normal?
Craft firmware and Fly app are latest versions.
2023-6-21
RoninOverFlight
Going to try re installing the app i guess as per this post "https://forum.dji.com/thread-278652-1-1.html" and see what happens
2023-6-21
RoninOverFlight
RoninOverFlight Posted at 6-21 09:52
No go, zero Expo tuning features under CINE mode after uninstalling and re installing app Iphone 12 mini.
2023-6-21
RoninOverFlight
Now my drone will no longer connect.
It was connected, i switched to Cine mode lost connection. After multiple phone reboots same issue ay hand can no longer connect to drone.
Drone starts flashing yellow, then on controller power on drone gies to steady green flash but i do not get an "Aircraft" connection pup up.
please help.
2023-6-21
Hi there. We're sorry for the trouble. We already coordinated this concern to our designated team. We will keep you posted. Thank you.
2023-6-21
RoninOverFlight
DJI Paladin Posted at 6-21 19:14
Strange and odd event happened earlier.
Had drone on table connected. Take off was GO. I kept drone on table no motor activation as i was simply tuning program parameters, while drone was stationary and connected I switched to Cine mode on Controller and I "Lost connection to drone."
very odd behaviour. I am on the latest ios release. Iphone 12 mini
2023-6-21
mikkymike
No Expo settings under any mode? DJi Mini 2, all these people on youtube telling you how to get a smooth flight, by using the gimble settings, yet they are not on my menu
2023-6-22
RoninOverFlight
mikkymike Posted at 6-22 05:13
I have expo setting under sport and normal modes but they are missing from cine mode.
sorry to hear you are missing the setting for all modes. Very odd.
2023-6-22
smbishop
Flight distance : 2454833 ft
I have DJI Fly 1.10.4, no expo settings for Cine mode, but can still adjust sensitivity.  Doesn’t this accomplish the same thing without the expo graph?
2023-6-22
RoninOverFlight Posted at 6-21 19:25
Thank you for your response. Can you please provide us a screenshot showing the Gain & Expo tuning on your DJI Fly app? Also, showing the Cine mode under that settings. If you provide a screen recording, that would be very helpful so we can further check it. Please keep us posted. Thank you.
2023-6-22
Joe Wells
Flight distance : 5839908 ft
smbishop Posted at 6-22 13:07
I have DJI Fly 1.10.4, no expo settings for Cine mode, but can still adjust sensitivity.  Doesn’t this accomplish the same thing without the expo graph?[Image]
The expo is for joystick reaction. If you put it all the way up, your joystick is very sensitive or not very sensitive. I can’t remember which way it goes. I know if you set it to be sensitive and just barely tap the joystick It will Move in that direction. and then if you make it not very Sensitive you almost have to full stick all the way to get it to react. I hope it helps. That’s what I figured out on my own.
2023-6-25
