How to Subject Track?
2939 3 2023-6-21
JSee
From what I can tell, there is no Active Track enabled for DJI RS 3 Mini and is not compatible with Raveneye. How do you track or follow a subject as mentioned on the DJI website? Thanks in advance!
2023-6-21
Hi there. Thank you for reaching out. Yes, the DJI RS 3 mini does not support the ActiveTracking feature. ActiveTrack is different from to "Track" feature on the DJI Ronin app. You may refer to the information below on how to use the "Track" feature. Hope this helps.
1. Tap “Create” in the Ronin App, and select “Track”.
2. Tap the virtual joystick icon to use the virtual joystick to adjust the camera orientation. Tap "+" to add (up to ten) waypoints. To delete a waypoint, select the waypoint and tap the trash icon.
3. Set “Movement Duration” (from 1s to 120 min), and “Stay Time” (from 0 s to 1 min).
Note: For the first waypoint, DJI RS 3 Mini does not support setting the movement duration, but supports setting the stay time.
After setting up the waypoints, you can tap Preview to make sure the Motionlapse includes everything or tap the shutter/record button to start shooting.
2023-6-21
fans7f81036e
Argentina
I though the same regarding subject tracking,  based on the mini page it says "tracking",  I only realize about that,  the feature is checkpoints follow, instead,  after I've checked the app available features. Maybe the word tracking for this feature is the source of confusion.
2023-7-17
djiuser_AWWto0UT9hBz
This honestly feels like false advertising. I got the RS3 mini because it says it does subject tracking. Having other DJI products, I KNOW that subject tracking meaning actively tracking the subject. Now I only find out it’s for specific Panasonic cameras? I would get Raven Eye, but THAT’s also not compatible with the RS3 mini. Super frustrating because now I have to decide if I want to go through the hassle of returning after opening everything. Not what I would expect from DJI.
5-18 21:01
