DJI Paladin
Hi there. Thank you for reaching out. Yes, the DJI RS 3 mini does not support the ActiveTracking feature. ActiveTrack is different from to "Track" feature on the DJI Ronin app. You may refer to the information below on how to use the "Track" feature. Hope this helps.
1. Tap “Create” in the Ronin App, and select “Track”.
2. Tap the virtual joystick icon to use the virtual joystick to adjust the camera orientation. Tap "+" to add (up to ten) waypoints. To delete a waypoint, select the waypoint and tap the trash icon.
3. Set “Movement Duration” (from 1s to 120 min), and “Stay Time” (from 0 s to 1 min).
Note: For the first waypoint, DJI RS 3 Mini does not support setting the movement duration, but supports setting the stay time.
After setting up the waypoints, you can tap Preview to make sure the Motionlapse includes everything or tap the shutter/record button to start shooting.
