Hello there. Thank you for reaching out. Osmo Action 4 inevitably dissipates heat when processing such a large amount of data in a short period of time, which is an irresistible physical law. The camera was designed with special attention to the heat dissipation issue. To ensure the normal performance of the camera, the internal heat is designed to be conducted to the lens cover, front and rear screens, and body itself through heat sinks and silicone grease. Additionally, strict tests have been made to ensure that the camera temperature is within a reasonable range during long-term recording. Osmo Action 4 focuses on sports scenarios such as skiing, diving, and cycling, where wind can assist the camera in heat dissipation when recording videos with a high resolution or frame rate, which, thereby, makes it possible to record longer videos. If you mainly use it to record your daily life or activities, we recommend you record at 1080p@30fps, as 1080p@30fps is currently the mainstream video format online, and it can also reduce your storage space and facilitate your editing afterward. Have a great day ahead. |
