GL300E and Mapbox bug
123Next >
7557 105 2023-2-11
fans02c008e1
Flight distance : 11909 ft
In my opinion, the solution is quite simple: you have to erase all the software and firmware on the GL300E and reinstall Android then the correct firmware for the GL300E and the correct DJI GO 4 for the GL300E. The problem is how to erase everything and do a clean reinstall of Android. If you have the solution, I'm interested because I don't know how to do it. Many thanks and have a nice day.
Mike
2023-2-11
Hi, fans02c008e1. Thank you for reaching out. Can you please explain what specific issue are you experiencing with the Mapbox on GL300E? Are you trying to reset the factory settings of GL300E? We will wait for your reply. Thank you.
2023-2-12
fans02c008e1
Hello, in fact since I updated my GL300E, maps and satellite photos are no longer displayed in DJI GO 4. I have tried everything to solve the problem but without success. I couldn't find a solution on the DJI forum. It's very disappointing. I think I think a possible solution would be to root the GL300E and do a clean reinstall of Android, firmware for GL300E and DJO GO 4 for GL300E but I have no idea how to do it while being sure not to damage the GL300E. In my opinion, there is this problem of a map that does not load just because of a lack of network connection when I am perfectly connected to a personal Wifi (just look a this photo)Have a nice day
2023-2-12
fans02c008e1
DJI Gamora Posted at 2-12 04:02
Hi, can you tell me the website where I can download with my PC the maps of Europe because since the update of the GL300E I can no longer download them. I then want to paste them on an SD card and transfer them to the GL300E. To do this, can you also tell me in which folder opened with the explorer of the GL300E I must then paste them.
thanks in advance
Mike
2023-2-12
fans02c008e1 Posted at 2-12 05:10
Hi, fans02c008e1. Thank you for the information. Sorry for the inconvenience, we already found and located this issue, and it will be optimized in future firmware version updates. Please pay attention to subsequent updates. Thank you for your kind understanding.
2023-2-14
fans02c008e1 Posted at 2-12 23:34
thanks in advance
Mike
Hi, Mike. Let me confirm with our relevant team if this is achievable. I'll let you know once I received an update. Thank you.
2023-2-14
thanks in advance
Mike
Hi, Mike. Thank you for waiting. Regretfully, this method will not work as well as per our relevant team. Kindly wait for the next update for GL300E to fix this issue.  Thank you for your kind understanding.
2023-2-15
djiuser_mdVToW4exih7
Very frustrating.
Many posts on line. Issue with Version 4.2.6. No maps.
Phantom 4 Pro+ was working fine then had issue at startup. Reset to factory. Updated lost mapbox.
Long talks with DJI tech about issue.
Was told there's NO SOLUTION at this time. Said engineers are working on a new version to correct.
Posts on this go back to at least 2020. No estimate on potential release date for update.
Was told a "solution" on the internet using  the DJI v4.3.14 apk will not work. Said installing a previous version will not work. No maps makes the drone more or less an expensive paperweight.
2023-2-24
djiuser_mdVToW4exih7 Posted at 2-24 11:26
Very frustrating.
Hi, djiuser_mdVToW4exih7. We understand why you're feeling that way and we apologize for the inconvenience. I have sent you a PM, kindly check. Thank you.
2023-2-25
thanks in advance
Mike
Hi, Mike. I have sent you a PM regarding an update with GL300E, kindly check. Thank you.
2023-2-25
djiuser_hpoyTOBgHBDE
Flight distance : 282123 ft
I am having the same issue with my controller since updating it some time back. Has DJI provided a patch or a time frame on a new controller update or update for GO4? Been a long wait
2023-2-25
Arczon
Hello, when can we expect new firmware to fix the bug? I need to prepare a map urgently for weed spraying treatments and the drone does not work! Please help urgently.
2023-2-26
Arczon
After 2 days to research... My map box is still blank.  P4P+
But I found a solution to the problem of how to use PIX4D for autonomous missions in such a situation.
You need PIX4D 4.3.1
ctrl+dji 1.9.1.
Add new map servers in PIX4D
cant post url only screen
2023-2-26
Good day, DJI Pilots. Please be informed that our engineers just released a remote solution and firmware that will rectify the map issues. You may download the firmware of the remote controller with a screen (GL300E) to the microSD card and then update the firmware manually. Refer to the instructions below for detailed steps.
1. Import the file “update.zip” into the microSD card.
Path for the remote controller firmware: (https://pan-sec.djicorp.com/s/6d4759ww3Z6EZCM).
2. Power off the remote controller and insert the microSD card.
3. Power on the remote controller and tap “Install.”
Kindly keep us updated. Have a great day!
2023-2-27
Mike B.
DJI Tony Posted at 2-27 00:04
hello Tony, I followed the procedure as you wrote it. But when going to the "resource data initializing..." step, the process goes up to 7 or 8% and starts again continuously at 0% and after a while nothing happens and the screen displays a panel saying "DJI GO 4 isn't responding. Do you want to close it?". If I check yes, the procedure restarts up to 8% and starts again at 0%.My GL300E is now totally unusable and I can't reinstall the latest version of DJI GO 4 because it fails every time
What to do ?
2023-2-27
Mike B.
help, my GL300E is now completely unusable. It loops between 0% and 8% and refuses to install new firmware
2023-2-27
Mike B. Posted at 2-27 01:39
What to do ?
Thanks for the update, and we're sorry to read about the errors. We will report this to our designated team for checking. Thanks for your patience and understanding.
2023-2-28
Mike B. Posted at 2-27 11:49
Yep same issue with mine. New patch firware hasn’t fix the issue. Made it worse, looping on 7% or 9% as well
2023-3-1
Hi, Mike. We're sorry for the inconvenience. Please check my PM. Thank you.
2023-3-1
djiuser_hpoyTOBgHBDE Posted at 3-1 03:06
Hi, djiuser_hpoyTOBgHBDE. We're sorry for the inconvenience. I sent you a PM, kindly check. Thank you.
2023-3-1
Hi there. We're sorry for the trouble experienced. We have received an update from our engineers. Kindly reattempt to update and proceed with the following:
1. Import this file to your SD card and try again: (https://pan-sec.djicorp.com/s/cmeQ9bfpqYg5SxZ).
2. If it still fails, kindly copy the update.zip to the internal memory of the remote controller and try again.
Thanks for your cooperation and patience.
2023-3-1
Mike B.
DJI Tony Posted at 3-1 21:39
Hi Tony, thank you for this file. It works very well. Out of curiosity, can you explain to me how it is possible to put the zip file in the internal memory of the remote controler and where when you cannot access Explorer? Best regards
2023-3-1
Mike B. Posted at 3-1 23:25
You are most welcome. Here's how to import it into the remote controller's internal memory:
1. Power on the remote controller. Connect it to your computer using a USB cable.
2. Go to the RC home screen, swipe down to access notifications, and select "USB Connected."
3. Tap "USB Connected,"  click "Turn on USB Storage," and select OK.
4. After this, you should be able to access the internal storage of your remote controller.
Sample pic for reference:
We hope this helps. Please let us know if you need further assistance. Have a nice day, and stay safe.
2023-3-3
Mike B.
DJI Tony Posted at 3-3 00:49
Merci Tony. Bonne journée à vous
2023-3-3
Mike B. Posted at 3-3 01:44
You are most welcome. Have a nice day!
2023-3-5
tkey24gmail.com
Flight distance : 10258445 ft
DJI Tony Posted at 3-5 20:49
Is this still an active fix for the GLE?
It is working again! Sweet.
2023-3-9
tkey24gmail.com Posted at 3-9 10:32
Hi, yes. This is the updated solution. We are glad to know this resolved your concern. Please let us know if you need further assistance. Have a nice day.
2023-3-10
djiuser_L19T7ooV7KiJ
Flight distance : 28520 ft
Panama
DJI Tony Posted at 3-10 23:43
Will this solve the mapbox problem?
2023-4-24
djiuser_L19T7ooV7KiJ Posted at 4-24 08:02
Hi there. Thanks for reaching out. Yes, as confirmed by our engineers and pilots who installed the recommended update. If you are encountering the same concern, kindly refer to the instructions posted (post #22). The link above may have expired already. You may install it from this link instead. Please keep us posted. Thank you.
2023-4-24
fans913aaa99
Can I have the link please? The one posted in #21 doesn’t seem to be live anymore.
2023-5-6
fans913aaa99 Posted at 5-6 13:08
Thanks for reaching out. Kindly try this link instead. Please let us know if it works for you.
2023-5-8
djiuser_zysKVsQKz8Py
I updated my application on 5/21/2023 to the latest version and the map menu does not work and the mapbox is black.  I tried to install the update.zip recommended above but the install would not complete.  If anyone knows of a current fix, please let me know as I would love this feature to work.
2023-5-21
djiuser_zysKVsQKz8Py Posted at 5-21 08:46
Hi there. We're sorry for the inconvenience. Can you send a screenshot of the error message when you update through the link shared above? Thank you.
2023-5-22
fanscee0ea08
DJI Tony Posted at 5-22 04:59
Hi Tony, can you upload the file again or send me a link.
I get a 503 server unavailable error
2023-5-23
fanscee0ea08 Posted at 5-23 19:58
Hi there. Sorry for the trouble. Please try this link instead: (https://pan-sec.djicorp.com/s/2mpYKtaWs2CHdxD). Please keep us posted. Thank you.
2023-5-24
jirepty
Flight distance : 239173 ft
Panama
Hi Tony, I'm here for help; I have already downloaded the zip file (post #36) when reviewing it there is no executable (.apk); I find for another .apk but when you run it,  no works (image 1);
Active the DJI GO4 application and when activating the maps it goes black (image 2),
I don't know what to do anymore... this is frustrating...
I appreciate the support;
Greetings;
2023-7-18
djiuser_tcDSggmQRCUo
Hungary
DJI Tony Posted at 5-24 09:59
Can you please send me a new link?
Thank you!
2023-8-22
djiuser_tcDSggmQRCUo Posted at 8-22 09:28
Hi there. Sorry about the late response. I have sent you a message. Kindly check your inbox. If you have further concerns, you can always reach back. Have a great day ahead.
2023-8-23
tafan
Flight distance : 1416014 ft
Can I also get a link to the update?
Thank you!
2023-8-30
tafan Posted at 8-30 09:33
Hello there. You can always reach back if you experience any other issues. Have a great day ahead.
2023-8-31
123Next >
