Maximum file size limit
647 3 2023-10-11
HarperDada
Flight distance : 11093 ft
Whenever I execute a waypoint mission of substancial duration, I see that the file is truncated to 3.76GB and the rest is put in a new file. Is this expected?
Best,
Harper
2023-10-11
No Original Thought
Flight distance : 1364275 ft
Yes, it's expected.
It's a limitation of the file system used on SD cards.
Almost all cameras that record to SD card will also truncate to somewhere around 4GB.
2023-10-11
The Saint
Flight distance : 6260171 ft
except there is no truncation going on here, no video is lost, no content is being removed; nothing is being shortened or squared off or reduced.  no need to try to use fancy words or whatever to describe what is going on. the file reaches a certain limit and it's done....a new file is started.
"To truncate a file means to reduce its size by removing some of its content."
for example 3.257 truncated could be 3
2023-10-11
Hi, Harper. Thank you for reaching out. No Original Thought is correct. It is normal as the external microSD card only stores a file with a 4GB limit size. A video file with a size of approximately 4 GB will be split automatically during storage in the microSD card. Hope this answers your question.
2023-10-11
