M3T mapping constraints (a work around?)
957 3 2023-11-12
Wyldeman
Purchased the M3T due to the value associated with the onboard thermal capabilities. I understand this does not possess the mechanical shutter as does the M3E. However, if attempting to use the M3T for mapping, would it just take much longer requiring the system to log images further apart and drone in turn travel much more slowly? Please also take into account, we utilize RTK accessories to maximize positional accuracy. And if not carrying survey-level compliance, is this capable enough for other applications? Is there software any of you use to help with these weaknesses?
2023-11-12
Hi there, thank you for reaching out. We will consult your questions with our engineers and get back to you here.
2023-11-13
Johnnokomis
Flight distance : 13593235 ft
The rolling shutter can be accounted for and mostly corrected in software like Metashape and others. The M3T doesn't handle RTK the same as the M3E does. It is talked about here:
Do the M3T/M3E w/ RTK Module employ Time Sync?
Ignore Wanda's replies there. Like usual, DJI's wording can be very misleading.
2023-11-13
Wyldeman
Thanks again John, look forward to digesting the thread. This post is actually a result of my interest in mapping our 27acre property to create a solid model in STEP format so we have an environment to use for future layouts/renderings. Even if it takes a long time to create or isn’t exactly perfect.
2023-11-19
