EnTuMente
necrome Posted at 11-17 22:30
@DJI Wanda
Does the DJI Mic 2 accept line-in outputs from a mixer or a sound board?
For example, can i record the audio of a church service by connecting the mixer output using an XLR > 3.5mm into the Mic 2 while recording video with the Osmo Pocket 3?
Most microphones of the Mic 1 or Mic 2 type allow you to connect a line through the jack input.
For example, I record concerts using the Mic 2 microphone connected to a table via an XLR to Mini Jack cable.
With this I am able to record the concert "on camera" with the sound that comes from the table and wirelessly.
But also, since the microphone has the option to record when you press the record button on the camera, I can also record a backup copy on the microphone itself.
Also, if you wish and to be able to record in 32 floating bits, you can desynchronize the microphone and be able to use the microphone as a line recorder. You just have to follow the steps explained above but without being paired with the camera. |
