DJI RC, Extended battery?
2059 20 2023-11-30
Potato mini
Flight distance : 7275348 ft
HI,
I'm a Mini 3 pro user with the RC, but the my RC has a horrible battery span. Has anyone out there made a battey extension, or some kind of extra battery you can attach to the RC?
thanks for the help
2023-11-30
Hi there. Thank you for reaching out. The operating time of the DJI RC with a fully charged battery is approximately 4 hours. You may use a portable power bank and charged the DJI RC while using as it supports this function to extend the battery life. Should you have other inquiries, feel free to contact us. We appreciate your valued support.
2023-11-30
jmb63
Flight distance : 7009439 ft
What do you mean by "horrible" ? How many Flights/drone batteries do you go through on a full charge on the RC? Are you constantly screen recording or something?
2023-12-1
Potato mini
DJI Paladin Posted at 11-30 21:24
4 hours? mine lasts 45 minutes, at best
2023-12-1
Potato mini
jmb63 Posted at 12-1 06:40
The battery lasts 45 minutes at most, not screen recording or anything.
2023-12-1
Potato mini
Dirty Bird Posted at 12-1 12:55
Your RC must have a weak battery.  With the screen set to Max brightness my DJI RC last 4 full Plus battery flights with more to spare.
Can i send it in to dji as a flawed product? or is there any way to replace the batterys?
2023-12-1
Potato mini
Dirty Bird Posted at 12-1 15:12
If it is still under warranty & you are only getting 45 minutes runtime you could make a warranty claim request.  If it is out of warranty DJI offers a repair service.  They will charge you the price of the battery plus a service charge, which I believe is $65.  Alternatively you could perform the repair yourself, if you find the proper replacement batteries, & if are competent in your repair skills.  The DJI RC is easier to open than many other DJI RCs.  4 screws, a spudger, & a bit of patience will get you into the shell.  The Mavic Pro/Mavic 2 style RCs were tricky & can be difficult to open with braking tabs or defacing the shell.  The batteries are electronically welded to the power leads, which is another hurdle if you don't have equipment to properly reconnect the replacement cells.  I will attach a video on opening the DJI RC.
Personally I would just send it off to DJI & let them do the repair.  No stress or worries about finding batteries, damaging, or defacing your RC.  Pay the fee & you are good to go.  Be advised you will NOT receive back your original RC.  You will receive back a new or like-new replacement.  Just bind it to your RC & you are up & running.
Thanks for the info. I drained the batterys to 0 %, and the  took apart the RC just to look around, I detached the batterys and then hooked them back up, and the batterys showed 65 %. Im going to take a test flight and make sure I didn't miss anything up, and I haven't charged the batterys since I took it apart.
2023-12-1
Potato mini Posted at 12-1 10:37
Thats really not right Potato,   I easily get 4 hours from mine.    Could you have a bad SD card in there?
2023-12-2
Yaros1
Flight distance : 21307762 ft
I would send it for replacement to DJI definitely.
Not a good thing that you opened it while it was on warranty.
2023-12-2
Potato mini
Yaros1 Posted at 12-2 05:05
How long does the warranty last? Look at post 9
2023-12-2
Potato mini
DAFlys Posted at 12-2 02:17
I have a lexar 128 Gig in my Rc and my mini 3 pro. I found out something really weird though yesterday. Look at post 9.
2023-12-2
Potato mini Posted at 12-2 10:03
Sounds like something isn't right,  Id be tempted to return it.
2023-12-3
Potato mini Posted at 12-1 15:24
Hi, there. We're sorry for the inconvenience. Please try to refresh the firmware of your DJI RC via the DJI Assistant 2 or simply visit this link.  After refreshing the firmware, please try to check the performance of your DJI RC again. If the situation remains, you may consider sending your product for proper inspection via this link: Online Repair Process I hope this information helps. Thank you for your support.
2023-12-3
Potato mini
DAFlys Posted at 12-3 03:52
It seems to be working great now, so I guess I'm just going to wait and see if the problem returns
2023-12-3
Potato mini Posted at 12-3 09:02
Thank you for keeping us posted. We're glad that the issue is now being isolated. Feel free to contact us if you have other inquiries. Have a nice day ahead!
2023-12-4
djiuser_9W4iyYyHmp1N
Flight distance : 891765 ft
Potato mini Posted at 2023-12-3 09:02
So would you say taking it apart, disconnecting the batteries and reconnecting fixed your battery issue? My RC controller drains way too fast after about 2 flights.
6-1 13:18
Potato mini
djiuser_9W4iyYyHmp1N Posted at 6-1 13:18
It worked for me but I would be careful. My rc lasts about 4-5 flights
6-1 14:22
Potato mini Posted at 6-1 14:22
Two flights and I'm down to 1 light flashing. Maybe unseating and reseating the batteries will make a difference. I would like to try before replacing batteries.
6-1 15:33
Potato mini
djiuser_9W4iyYyHmp1N Posted at 6-1 15:33
I would give it a go and hope for the best. worst case scenario you would only need to buy new batteries. bare in mind if you open the rc it will void any warranty you have on it from dji.
6-3 12:10
John Kay
Potato mini Posted at 6-3 12:10
Ok had about 25% battery and went ahead and opened up my controller. Pulled the connector for one of the batteries and reconnected, carefully partially put back together to turn on and check the battery level. 3 of the 4 bars were now lit and 75% battery. It worked! Thank you so much for your post, you saved me. Hopefully no more anxiety about my controller running out of battery while flying. Have a great day.
6-6 22:34
Potato mini
John Kay Posted at 6-6 22:34
Awesome! Glad to have helped. Have a wonderful weekend
6-7 15:55
