Damianoo Posted at 10-10 00:10
Yes, I used HDMI to output the signal to an external monitor. Very often the problem occurs, but there are areas where the signal is better and there are areas where the signal is very bad.
I am deeply sorry for the belated reply. As you have mounted the HDMI module, could you please try to remove it and check again?
If it was caused by the HDMI module, this phenomenon is caused by the noise when the device is connected via the HDMI cable, which affects the image transmission. We recommend you to use a cable with higher quality and longer length so that the monitor can be kept away from the remote controller to reduce interference.
If it is not related to the HDMI module, please note that flight distance sometimes relates to the flight environment, we would suggest that you fly the drone in an open wide area, as obstacles may weaken or block the signal. Check the antennas position of the remote controller. Distance should be greater than height during flight, and please make sure the remote controller’s antennas are positioned parallel to and are pointed towards the aircraft, update your drone and RC to the consistent or latest version. Besides, please check the interference of the current flight channel, please change to a channel with less noise if needed. If the issue happens in different open areas, you may consider sending it in for further check.
Please click the "Reply" button if you reply to me so I can receive the reminder. Thank you.
