Jan Spacil
Czechia
@all: Please don't worry about how I use the battery. I was asking about the possibility of only charging the battery in the drone to ~60%.
I only have one drone, with one battery, and I occasionally fly it for fun. When I get home with a drained battery, I connect the powered-off drone to my PC to download photos and videos and let the drone charge at the same time. The low charging current does increase the charging time, but again, it is more battery-friendly.
I don't have the capacity to check how many LEDs are blinking right now, I just unplug the drone after some time and put it in the box.
Then when I want to fly again, I have to charge the drone again from about 60% to full, which seems unnecessary, but I can't do anything about the automatic discharge.
Leaving the battery discharged and charging it before flying doesn't seem like a good idea to me.
@Dirty Bird & harweyko: Thanks for the info, that's probably exactly the solution that might work. I'm a bit worried about the battery clips operation (hopefully the plastic of the clips is a bit better quality than the M3/Pro), but this external charger would solve the problem. |
