Hi, there. Thank you for reaching out. Please consider using the QuickTransfer method for transferring files from the aircraft to the mobile device. To perform the QuickTransfer feature, you may follow the instructions below. Furthermore, other methods of transferring files can be checked via this link.
1. Power on the aircraft and wait until the self-diagnostic tests of the aircraft are complete.
2. Make sure Bluetooth and Wi-Fi are enabled on the mobile device. Launch DJI Fly and a prompt will appear to connect to the aircraft.
3. Tap Connect. Once successfully connected, the files on the aircraft can be accessed and downloaded at high speed. When connecting the mobile device to the aircraft for the first time, press and hold the power button of the aircraft for two seconds to confirm.
I hope this information helps. Thank you for your support. |
