C1 classification application system error on address entry
4615 79 2023-4-6
RJD
I am trying to apply for C1 classification and getting a little desperate here - I am located on the Canary Islands, we are part of the EU, but every time I enter the address it returns a 'system error, try again' message. Even when I try to contact the online support and it asks me to select my region and I choose Europe, it will tell me that it has detected I am not in Europe. I also considered havin it sent to some of my family in Germany but I can change the country selection away from 'Spain' in the address (it is the only part that is filled in and is greyed out) any help will be greatly appreciated!
2023-4-6
Hi there. Thanks for reaching out, and apologies for the inconvenience. Kindly confirm if the drone meets the following conditions:
a. Drone type is Mavic 3 or Mavic 3 Cine;
b. DJI APP version is 1.9.0 or above and Firmware version is 01.00.0900 or above;
c. Drone now in the European Economic Area (EEA).
If not, kindly ensure to update the app or drone's firmware. If it does, and the error remains, please let us know so we can submit a manual application for you. Thank you, and have a good day.
2023-4-7
RJD
DJI Tony Posted at 4-7 23:28
Dear Tony, many thanks for your reply - I can confirm all of the above:
Drone is Mavic 3
DJI App is running 04.13.0800 and firmware version is 01.00.1000
The drone is now in the European Economic Area
Unfortunately the problem persists
2023-4-8
RJD Posted at 4-8 00:14
Drone is Mavic 3
Thanks for the confirmation. We'll be sending you a PM to gather some necessary details for the application. Kindly check your inbox and respond at your earliest convenience. Thank you.
2023-4-8
djiuser_KRFDV99bzzyH
DJI Tony Posted at 4-8 03:54
Hi Tony.
I'm having the same issue here. My drone and my controller are updated and I live in  European Economic Area.
2023-4-17
djiuser_KRFDV99bzzyH Posted at 4-17 10:42
Hi Tony.
Hi there. Thanks for reaching out, and apologies for the inconvenience. We will send you a PM to gather your information. Kindly check your inbox at your most convenient time. Thank you.
2023-4-18
tmbinc
DJI Tony Posted at 4-18 00:45
I'm having the same problem - verified the things above, but get a "System Error" when adding my address.
2023-4-28
djiuser_0hwhqzRdoKiI
Flight distance : 66086 ft
Hi, this is happening to me too. Trying to register a new Mavic 3. Firmware updated to latest on drone and controller this morning. Everything seems fine on drone. When I click on the C1 label bit, it wants an address to send it to but the DJI Fly app returns a yellow/orange system error, try again later message. Tried yesterday several times with previous firmware version and today several times with new latest firmware version. Not working. Drone is physically in Spain. Same when trying to add an address via the website. What is the fix? Best to all from southern Spain,
2023-4-28
tmbinc Posted at 4-28 06:58
Hi there. We're sorry you're experiencing the same issues. We have sent you a PM. Kindly check your inbox at your most convenient time. Thank you.
2023-4-29
djiuser_0hwhqzRdoKiI Posted at 4-28 07:14
Hi there. We're sorry for the inconvenience. We've also sent you a PM. Please check your inbox. Thank you.
2023-4-29
djiuser_TkilxgwnFFEk
Flight distance : 55850 ft
Hi there,
Same to me, I'm in Spain too, tried several times to obtain the c1 label but always get the "system error, try again later" entering my address. I have a Mavic 3, last firmware, app updated.
Thanks in advance.
Regards.
2023-4-30
RJD
djiuser_TkilxgwnFFEk Posted at 4-30 08:02
Hi there,
If you get in touch with support they'll dial it in manually for you and send you the stickers
2023-4-30
Hi there,
Hi there. We're sorry you're getting the same error. We've sent you a PM. Kindly check at your earliest convenience.
2023-5-1
djiuser_v9sO6mhWPpJs
Flight distance : 182687 ft
C1 Label Schweiz ist aktiviert!!
Thank you very much
Super! Heute 13.Mai 23, OHNE problem, via DJI APP, meine C1 CERTIVIZIERUNG beantragt. Vielen Dank,  Manuel
2023-5-5
Patrick8639
Same thing here.
With application and drone at the latest version, I can finally ask for C1 certification in Switzerland.
The problem is that the application doesn't accept my address and displays "System error - Please try again later"...
Fprtunately, the drone firmware seems to have less bugs...
2023-5-7
DJI Wanda
djiuser_v9sO6mhWPpJs Posted at 5-5 13:29
I have the same problem with Confirm my address in Switzerland.(system error). Can you help for this. What can I do , Apply for the c1 label
greeting Manuel
Hello, there. Sorry for the inconvenience. May we know if your issue is resolved? You can contact our support to help you. Here is the link:https://www.dji.com/ch/support/repair?from=store_homepage
2023-5-7
DJI Wanda
Patrick8639 Posted at 5-7 03:53
Same thing here.
Here there. May we confirm if you successfully applied for the label now?
2023-5-7
LuciMain
Flight distance : 934327 ft
Maybe this is helpful for you... wrote it in a different thread here in the forum  https://forum.dji.com/forum.php? ... 867&pid=3035819
2023-5-10
Ziv.ishshalom
Flight distance : 824606 ft
Hi, was this issue resolved somehow?
I am trying to add my address (Germany) and I get "System error, please try again later." error.
Tried also adding an address via https://repair.dji.com/mycase/myaddress but I am getting the same error.
2023-8-12
DONATI-LAB
Hello, my M3E just arrived and when trying to apply for C2 certification i got a "System error, please try again later" too. Same if I try to add the address on the Service Request and Inquiry page.
2023-12-20
rcoutard
Hello
I have the same issue trying to get my stickers for a new Mavic 3 cine, I'm located in France. Any help ? Thanks !
1-20 06:38
Gert Kracht
Flight distance : 409085 ft
Hello, I get a 'Network exception' error message when applying for my C1 registration of my Air 2S.
Can you please help me out. I tried many time but the red error message is very persistant.
I updated both my Air2S and RM330 to the latest firmware.
Thanks,
Gert
1-24 13:10
Killerbee
Flight distance : 64820 ft
Gert Kracht Posted at 1-24 13:10
From Facebook DJI:
DJI  Update: The release of the C1 label for the Air 2S is now scheduled for early March instead of late January as originally planned. We have encountered additional complexities that require thorough attention and resolution and appreciate your anticipation. Stay tuned for an even better experience!
1-24 13:34
Gert Kracht
Killerbee Posted at 1-24 13:34
From Facebook DJI:
Thank you. I hope they will succeed in releasing the update.
1-24 15:56
Naturekid72
Flight distance : 69357 ft
Same problem here in Germany..
Newest firmware
Mini 4 pro
Kind regards
Joerg
1-27 06:12
PatiKuba
Same happens here. Spain
Why this is still not fixed all the firmware updats installedMini 3 Pro
1-31 04:05
djiuser_gZCjhy7cKXg9
Flight distance : 36070 ft
Hi, I have the same issue, what should I do, everything is up to date
2-3 04:59
djiuser_y0nFQ4Et72QG
Flight distance : 43501 ft
DJI Tony Inserito il 7/4/2023 23:28
Ciao a tutti. Grazie per averci contattato e ci scusiamo per l'inconveniente. Si prega di verificare se il drone soddisfa le seguenti condizioni:
a. Il tipo di drone è Mavic 3 o Mavic 3 Cine;
B. La versione dell'APP DJI è 1.9.0 o successiva e la versione del firmware è 01.00.0900 o successiva;
Ciao ho lo stesso problema dall' Italia non riesco a salvare l'indirizzo per richiedere la certificazione mi puoi aiutare mavic 3 tutto aggiornato
2-6 04:50
djiuser_y0nFQ4Et72QG Posted at 2-6 04:50
Hi there. Please make sure your drone model is Mavic 3 or Mavic 3 Cine, the DJI APP version is 1.9.0 or above and the Firmware version is 01.00.0900 or above. I have also sent you a message to assist you further, please check your forum inox. Thank you.
2-7 01:47
djiuser_gZCjhy7cKXg9 Posted at 2-3 04:59
Hello. Sorry about the trouble. I have sent you a message. Please kindly check your inbox. I appreciate your patience.
2-7 01:53
djiuser_w7Nq9Y9K30mh
Flight distance : 479610 ft
I'm getting the same issue with my Mini 3 Pro. Although I could add the address directly via repair website, when I submit my Class Identification Label Application request I get error.
2-9 09:05
fans608a3a3f
Flight distance : 586194 ft
DJI Tony Posted at 2023-4-7 23:28
***Update - I managed to enter an address on the repair site, so problem solved.
Hi Tony,
I'm having the same problem with the Mini 4 Pro. Can you help me?
Kind regards,
Tim
2-9 10:42
fans608a3a3f Posted at 2-9 10:42
Awesome. I'm glad to know it was already solved. You can always reach us if you need further assistance. Have a great day ahead.
2-10 03:29
djiuser_w7Nq9Y9K30mh Posted at 2-9 09:05
Hi. Sorry about the inconvenience. May I know what error are you getting? Thank you.
2-10 03:31
DeeWay81
Flight distance : 22431 ft
Update:
go to the page and enter this adress: https://repair.dji.com/mycase/myaddress
Done
Hello from Germany
same problem
DJI Mini 4 Pro ... C0 to C1
The error occurs in the address entry -> "System error"
please help
2-22 08:25
Davidmenk3
Pakistan
It seems like there might be an issue with the C1 classification application system, possibly related to address entry. This could be due to an err connection reset error. You may want to check your internet connection or contact support for assistance.
2-23 03:35
mieszek2
Davidmenk3 Posted at 2-23 03:35
I have the same issue. mini 3 pro, DJI RC-N1(Model RC231). wifi working, all firmware updated. there is some (empty) error appearing for 2-3 seconds when I enter Cx Label window. when I submit form "Network Error" appears for a moment. This looks like DJI Fly error
2-23 06:53
djiuser_akQCadkm49GZ
Flight distance : 5387 ft
Same issu with the Mini 4 pro. I am Not able to save the adresse and proceed.
Best regards
2-23 11:29
djiuser_OThYzKE1gmlq
I have the same problem with the Mini 4 pro. Updated my firmware but can't add my address.
What can I do?
Best regards
Philipp
3-6 12:28
fansf3575fa1
Why aren't they putting the labels in the box instead of making customers jump through these hoops?
Has anyone run into police or other authorities demanding to see this label?
3-6 18:37
