Webcam disconnecting
1718 30 2023-11-9
fans07faac6b
Flight distance : 139521 ft
Austria
I am using the Pocket 3 as a webcam on an M1 Mac with the newest MacOS and it works fine when connecting the cables, but after a few minutes, the image randomly disappears from the Mac but on the Pocket 3 it still says Webcam (30fps).
If I then reconnect the cable, it will work again for a while.
Usually I use the webcam for 30 minutes at a time and I can never get through it without it disconnecting once.
2023-11-9
Hi there, sorry for the inconvenience caused. For this issue, we will forward to our engineer team to check on it. We will keep you updates.
2023-11-9
Hi there, in order to better to indentify the issue, we would like to know more details about the working condition. For example, is the pocket directly connected to the mac or with Battery Handle or the 1/4″ Thread Handle?
At the same time, we would like to know the time when the issue happened. And if it is convenient, please also provide us the device logs for further checking, thanks.
2023-11-9
Kevin94
Austria
I have it connected through the regular 1/4" handle. The log files are pretty big (1gb) but the issue occurred between 9:40am and 10:30am CET. I uploaded the log files to my Google Drive
https://drive.google.com/file/d/1WXksswTa6HBWmopn86C5G9TMRoEC5_dz/view?usp=sharing
2023-11-9
Akira Wing
I am seeing the exact same issue with my M1 Mac and Pocket 3 as a webcam as well. Using the battery handle and regular handle.
2023-12-2
Poney Airways
I have the exact same issue.
Pocket 3
Macbook Pro M1 Max 14"
Pocket 3 connected directly to the Mac USB-C port
Software: ZOOM
Time before interruption: Around 20 min
Cable used: the one in the box
1-4 01:40
egorr
Armenia
same issue., but affects both webcam and file transfer modes
Pocket 3
Macbook Air M1
Time before interruption: Around 20 min or less
Connection: direct to osmo, battery handle, simple handle, all cases the same
1-16 01:49
SimonMW
Flight distance : 361263 ft
I have this webcam problem as well. I've also had the camera disconnect from USB while transferring files as well, so it seems to be an issue with the USB connection to the Pocket 3 in general.
1-24 04:40
djiuser_rnbXFi8OsNqQ
Mexico
Same here! I even tried different cables!
1-30 06:56
Heimdallby
A client of mine also has this problem on a M1 Macbook Pro.
Is there a fix for that soon?
2-2 00:01
kwm
South Korea
Same problem here...
M1 MAX Macbook Pro
Osmo Pocket 3
Usb-c to Mac directly
Only 30min is the best recording time...
Please Fix this problem
Osmo P3 is not a webcam to the Mac users now...
2-8 02:15
kwm
South Korea
M1 MAX Macbook Pro
Osmo Pocket 3
2-8 02:16
kwm
South Korea
DJI Thor Posted at 2023-11-9 03:40
is there any update for this issue?
as you can see, so many people got same problem here
2-8 02:20
kwm
South Korea
2-8 02:20
kwm Posted at 2-8 02:20
Hi kwm, sorry for the late response. We will forward to our engineer team to further check on this issue. Once we get the results, we will keep you update soon.
2-8 17:18
Hi kwm, after checking with our engineer team, the issue should be caused by the compatibility of our products with computers or with third-party software that requires the use of cameras.
We apologize for the inconvenience and will also forward to our relevant team for evaluation to enhance our products in the future. Currently, it is suggested you could try to change the software or computer to use it with. Thank you for your understanding.
2-10 19:14
fans2626795e
Flight distance : 1710968 ft
DJI Thor Posted at 2-10 19:14
That is really not a great option. It effectively means that the OP3 is useless as a web cam. Great pity, as it had become a core use for me, but I cant tolerate the recurrent disconnections. DJI need to resolve this as a priority
2-19 14:38
djiuser_ax1QE1iOxEg8
Mexico
When I use the USB-C cord directly from the OP3 to my M1 Mac, it gets disconnected in about 20 minutes. BUT, when I use a third-party USB-A to C cord, connected through a 7-in-1 USB hub in my M1 Mac, I HAVE NO ISSUES AT ALL! I don't understand why, but you can try this workaround and let me know if that works for you. (The cord is a 65W Super VOOC Fast Charge USB-A to C from Oppo)
2-19 19:28
djiuser_4oZQVY8CpHtM
Slovakia
I am disappointed that this problem is not solved. Cant using Osmo Pocket 3 as webcam on my Macbook Pro M1
3-27 02:09
Slovakia
fans2626795e Posted at 2-19 14:38
Try to not flip the camera on your self. Instead use front camera and just use joystick to move and point the camera on yourself. For me, this was a solution.And dont use extended battery.
3-27 05:00
djiuser_4oZQVY8CpHtM Posted at 3-27 02:09
Sorry for the inconvenience. We'd like you to know that we appreciate your valuable suggestions. We will forward your concern to our engineers department. All significant suggestions will be implemented after the evaluation of our relevant team. For the latest updates please stay tuned to our DJI official website at ( www.dji.com ). Thank you for your understanding and support.
3-27 23:10
Slovakia
DJI Thor Posted at 3-27 23:10
I solved the "freezing" problem. Camera (as webcam) freezing after a while, if you flip the camera to the "self recording" (selfie flip)  mode. The camera try to mirroring the screen and this was causing the freezing problem. Now i dont flip the screen (just use 5D joystick to point on me) and the camera work without any problems. DJI technicians need to solve the problem with the "selfie flip" freezing problem in webcam mode. I am on Macbook Pro M1. Sorry for my English
3-28 06:04
KIRILLNE
tell me if the 60 fps mode worked for you, when it’s turned on on the camera it’s still not displayed in OBS on Windows, the limit says 30 (usb port 3.0
3-28 15:56
Slovakia
KIRILLNE Posted at 3-28 15:56
I have no problems with 60 fps. Both 30 and 60 fps works well with OBS on Macbook Pro M1
3-29 05:23
djiuser_4oZQVY8CpHtM Posted at 3-28 06:04
The stabilization of the Webcam function is related to macOS system compatibility. If there is any issue with this function, you can update their macOS system. MacBook Pro M1 2020 System 11.2.3 Supported. If the issue still exists, please provide us with a video for further checking.
3-30 02:38
fansa94ad1f5
just for curiosity, because it happened to me also. Have you checked the time to switch off screen while recording at your configuration. I am not sure, but I have put that preference to never and it is not happening now. I need to check more, but..... my 2 cts
3-30 21:14
djiuser_Tn27CtuLL2Ja
djiuser_ax1QE1iOxEg8 Posted at 2-19 19:28
Thanks! This 100% worked for me using a cheap usb-c multi port dongle and a generic usb-a to c cord.
4-29 03:11
cd_racer
Regarding the OBS: try to set fps on the Video tab to the camera fps or 2x of camera fps. Tested the latest version of the OBS and seems it works. Camera freezes when I set fps on camera to 30 and 25/50 in OBS but all is ok with camera fps at 25 and 25/50 in OBS. Also I prefer to set camera fps in the properties of the camera in OBS.
5-4 04:19
dcscot
djiuser_Tn27CtuLL2Ja Posted at 4-29 03:11
This worked for me so far too.....1hr in to a test Zoom and not crashed. Not tried selfie mode yet though.  Support just recommended I remove the memory card but that made no difference.  Shame they don't know the solution that's in their own forum.  I'm on a Mac.
5-15 22:48
neotint
I've had the same issue too. In Zoom meetings the OP3 would disconnect after about 15-30 minutes.
But in testing it today webcam mode works without issue, perhaps the recent May 2024 firmware update fixed the problem?
Test 1: May 19, 2024
Pocket 3
Macbook Pro M1 Pro 14"
Pocket 3 connected directly to a Macbook USB-C port
Cable used: the one in the box, I've tried the included cable and Samsung cable for an SSD.
Tested for 90 minutes without a problem.
As before the UI shows the battery icon as not charging, but it stays at 97%, so it must mean the power fully comes from the Macbook.
5-19 09:16
neotint
May 20, 2024 Update: the webcam is still disconnecting!
Test 2: May 20, 2024
  • Pocket 3
  • Macbook Pro M1 Pro 14"
  • Pocket 3 connected directly to a Macbook USB-C port
  • Cable used: the one in the box
  • Firmware: May 15 20224
  • Using Osmo Pocket 3 Handle
I was on a 2 hour training as the lead facilitator.
OP3 lost webcam mode state 3 times.
Each lost connection event was about 20-40 minutes before losing the webcam mode.
The disconnection is behaving differently than before the latest firmware update. Now the OSD immediately prompts to choose file transfer mode or webcam mode. I selected webcam, then it disconnected immediately — it did this 7 times. Then I turned the OP3 off and on again, then the webcam mode worked... until it didn't about 30 minutes later. But the reconnection only took one try. So webcam mode is more erratic now than before.
Please find a fix for this so we can rely on using the webcam.
  • Is it a USB bus power draw issue on my MBP M1?
  • Is it a fault with the OP3 Handle?
  • Is it a firwmware bug?
  • Multiple issues?
Please escalate solving this. The viceo quality and 1 inch sensor and 20mm lens is great for webcam use!
Thanks!
5-21 05:11
