Bersecti
Flight distance : 324203 ft
DJI Gamora Posted at 4-4 03:45
Hi, Bersecti. Thank you for reaching out. Can you please confirm if you're trying to record audio from the RC 2 (with Comica C3) while flying the drone or during screen recording?
I am just on the ground not even connected to the drone but the end goal is to take the audio from the screen recording and include it on the 4K drone footage in post but I’m still experimenting.
So far I have just hit screen record on the RC with the C3 receiver plugged into the USB C port on it without the drone even powered on. Then i just change to the Settings screen or the Profile tab and talk away into the C3 transmitter/mic. I can see the audio levels changing on the receiver so I assume the C3 is working fine.
C3 receiver has both the usbC output on one side and a 3.5mm audio out jack on the other. I assumed it would be good to go with usbC cable direct the same as the DJI mic but using a cable instead of the cool little fixed usbC adaptor the DJI one comes with. So far i can’t hear audio on play back whether i use the usbC cable only or the 3.5mm TRS to TRS cable and also the TRRS to TRS cable in conjunction with the 3.5mm to usbC monitor adaptor in the pic.
Bear in mind i am only assuming there is no audio because i can’t hear it on play back on the RC2 speaker. I have not tried transferring the card to a card reader but that MIGHT lead to problems along the lines of my other question. I will then have Android files on that card I am trying to open, watch and listen to on my IPad Pro running ipad OS 17.4.1
