Phantom 4 pro update error 0x020103
4696 27 2017-11-9
josjr
Flight distance : 409268 ft
Hi guys.
I'm having a new phantom 4 pro introducing error 0x020103 during upgrade.
I heard there is a .bin file to solve this problem but I could not find it.
Can someone help me?
2017-11-9
Hi, Josjr, I had shared the link to the .bin file via PM. Please follow steps below.
1. Power on the drone, ensure it is not upgrading yet;
2. Copy the file to the SD card, insert it into the drone;
3. Pay attention to the camera indicator, it will change from red/green light to solid green, the whole process might take 1 minute;
4. Once it finishes, update to the latest firmware.
Hope it helps.
2017-11-10
josjr
thanks!!!!!!!!
2017-11-10
Hi, got your PM, please copy the file to the root of the SD card, it would be better to just leave the bin file in it.
2017-11-10
RyanMcCabe
DJI Thor Posted at 2017-11-10 23:58
I'm having the exact same issue. Could you please direct me to a copy of the .bin file?
Thank you.
2017-12-19
RyanMcCabe Posted at 2017-12-19 08:52
Thank you.
Hi Ryan, I would like to help, I had PMed you the Dropbox of the bin file. But please notice that it can only solve the same error code for Phantom 4 Pro and Adv. It won't work if it is not the same case. So please confirm it first. Thank you.
2017-12-20
RyanMcCabe
DJI Thor Posted at 2017-12-20 00:43
Worked like a charm, thank you very much.
2017-12-20
RyanMcCabe Posted at 2017-12-20 10:37
No problems. Should you have any further questions, please feel free to contact us. We'd glad to help.
2017-12-21
fansf63b15d9
Flight distance : 1637933 ft
Hi
I have the same error with my P4Pro and cannot proceed with updates and now it won’t connect to the controller at all.  Have tried using DJI assistant but keep getting the 20103 error. Can I please have the link to this file also?
2017-12-22
Cepeto
Hello, i have same problem, can i have the bin file please for SD Card. ceto75@hotmail.de
2018-6-5
Henry Castañares
Philippines
Need help poh. .may Phantom 4 ad. is black on screen .this is the error.
i've try to update but it cant complete the update. i do know its something wrong. .please hellp.
2018-7-3
Henry Castañares
Philippines
2018-7-3
idinabdi
Iran
DJI Thor Posted at 2017-11-10 00:04
hi.I have same problem.please send me .bin and pm files.tnx
2018-11-29
idinabdi
Iran
hi.please send me .bin file I have same problem
2018-11-29
Hatem m
Flight distance : 3430463 ft
Saudi Arabia
I have the same problem. Can I send a bin file to my h500200@gmail.com mail?
I didn't find a fix.
2018-11-29
idinabdi Posted at 11-29 00:16
Hi idinabdi, could you please share the screenshot of the error message that you got for a double check? Look forward to your reply.
2018-11-29
Hatem m Posted at 11-29 05:22
Sorry for the late reply, Hatem. The error message that you got is not the same case as the OP.
Please try to update the firmware again by the DJI Assistant 2, you can wait for the DJI Assistant 2 prompts you to update after connecting. If the error persists, please kindly click the "Upload Error Log" and provide me with your DJI account, I'll try to double check your case with the engineers.
2018-11-30
KylePolansky
Flight distance : 232923 ft
I'm running into a similar problem with a brand new Phantom 4 Advanced. The DJI Go 4 app says: "Battery signal error. Please check the battery connection.". The battery level shows an overall voltage, but 0% battery life and no serial number or firmware version or anything. When I try to refresh the firmware from DJI Assistant 2, I get the error code: 0x020b03 alongside a battery error. I have tried the following:
-Discharged the battery completely and recharged to 100%
-Restarted the DJI Assistant 2 app, the drone, and the DJI Go 4 app
-Uninstall and reinstall DJI Assistant 2
-Factory reset using DJI Assistant 2
-Firmly push the drone battery into the drone as it is powering up
-Tried with and without a micro-sd card
-Tried powering up with the drone connected to the DJI Go 4 app with the OTG cable
-Tried firmware refresh from DJI Assistant 2 app from a Mac computer
-Tried firmware refresh with another microUSB cable
Any Ideas?
2018-12-1
squishall
I have same problem as OP. Very frustrating. may I have the .bin file please?
Thank you.
2020-8-28
Ahithopel
Israel
I have the same problem. Can somebody share the .bin file with me please?
2020-11-16
datadave
Flight distance : 90709 ft
Please, please can you help with the same fault as I cannot even get DJI assistant 2 to re flash the original firmware. It comes up with the same error code as mentioned here. Can you help me with the use of that bin file please. Many thanks to all. You have been a great help to my friends as well.
Cheers Dave
2020-12-8
Rossbro2
I am getting error code 0x020b03 after trying to refresh P4P firmware to 1.05.0600 and now drone is beeping constantly.  DJI Assistant 2 gets to exactly 29% every time then fails, saying "Battery update error.  Please disconnect and re-insert the battery.  Aircraft will try repairing automatically.".  Please help!  Would love to try this .bin file/SD card method ASAP   Thank you!
2021-4-2
djiuser_g68cX2MwppNn
Flight distance : 4163 ft
Hi, I have the same problem. how can i get the .bin file?
2021-8-10
alex.marchequipmentstore
Flight distance : 70308 ft
Malaysia
I have the same problem. The DJI Go 4 app says: "Battery signal error. Please disconnect and re-insert the battery. Aircraft will try repairing automatically". How to solve the problem?
2022-12-12
djiuser_mdpndBsONm9Q
Having the same problem I believe, hoping I can get the .bin to fix this
4-29 12:40
djiuser_mdpndBsONm9Q Posted at 4-29 12:40
Hi there, sorry for the late response. You could try as follows, and hope it could help.
1. Restart the device and try to upgrade again.
2. If DJI GO 4 is used to upgrade, please try again by using DJI Assistant 2.
3. If the upgrade still fails, let him wait in the upgrade interface and try to fix the issue with a consistent upgrade.
If the upgrade fails again, use DJI Assistant 2 to upgrade and check the error code. If the error code shown in the following picture is displayed, it is camera upgrade failure.
5-4 05:06
DJI Thor Posted at 5-4 05:06
I have tried numerous times over the last few weeks, and the result is the same.  I have not tried using DJI Go 4 (unless that is the one on the controller) which I will try.
your step 3. indicates a 'consistent upgrade', I'm not totally sure what you mean by this, could you please give me or direct me towards a step by step for that process?
Thanks for your help!
J
5-13 08:26
djiuser_mdpndBsONm9Q Posted at 5-13 08:26
Thank you for your reply. You could try it first. And if the upates still fails, it is suggested to send back your Phantom 4 Pro to our service center for further product inspection, thanks.
5-14 07:31
